Do USDM ITR pistons stick out of the block?
Old Apr 7, 2009 | 06:47 AM
japscrap's Avatar
Default Do USDM ITR pistons stick out of the block?
Do they? What do the reliefs on GSR pistons look like?
Old Apr 7, 2009 | 12:36 PM
Ausmith's Avatar
Default Re: Do USDM ITR pistons stick out of the block?
Of course this depends on the block, crank, and rods you are using...
If you are talking about a stock ITR bottom end, no, the pistons should be in the hole.
Old Apr 7, 2009 | 01:50 PM
japscrap's Avatar
Ya ITR block, crank, rods. How far should they sit in the hole? Any way to distinguish them from GS-R pistons without using the casting numbers?
Old Apr 7, 2009 | 08:08 PM
Shawn C's Avatar
In The Garage
the domes on stock itr pistons stick out, the head is flush. gs-r pistons are flat-tops that are flush with the deck surface. both have same crankshaft, rods, and pin height (sure, the R's get the good stuff ). i'm also describing usdm stuff here. the jdm itr's stick out a little more, the jdm SiR-G (Japan's GS-R equivalent) has slight dome pistons. the B16 pistons stick out a little more, and the ctr's have the greatest dome height
Old Apr 8, 2009 | 03:00 AM
japscrap's Avatar
cool, thanks
Old Apr 8, 2009 | 04:25 AM
MiraiZ's Avatar
theyre ya go...these are JDMs tho
Old Apr 8, 2009 | 01:43 PM
japscrap's Avatar
Mine are level on the sides but the center sticks up out. I guess they're Type-R.
eg4life1202
10
Dec 1, 2018 11:05 PM
Rease3
24
Jul 23, 2009 06:13 AM
importboi22
Jan 31, 2005 10:28 PM
4drDC2
Jan 22, 2005 03:08 PM
-iLLuZioN-B18C1
Mar 7, 2003 10:02 AM
