Engine start up problem (Crank intermittently)
Old Apr 7, 2009 | 01:06 AM
kc7's Avatar
kc7
Default Engine start up problem (Crank intermittently)
When i start the car by turning the ignition key, the cranking is kinda funny in this sequence "crank noise, crank noise, no noise for 1 sec, crank noise, crank noise" then engine roars. Sometimes the sequence repeated and stretch longer before before engine roar.
What could be the problem? Please help.
Old Apr 7, 2009 | 01:43 AM
GhostAccord's Avatar
Default Re: Engine start up problem (Crank intermittently)
Check both battery connections to ensure they are tight and clean (free of corrosion). Use a voltmeter and check your battery voltage and or have your battery load tested at your local parts store. There are parts stores that will do a full battery test for free.
Old Apr 7, 2009 | 04:12 AM
kc7's Avatar
kc7
Thanks again! Will check on the voltage myself (nothin comes free the place where i stay) but what values should show up if battery is near death.
Old Apr 7, 2009 | 05:12 AM
If it drops under 9v when your cranking/trying to start it that is a good sign that it's going south. If it jumps back up to 13-15.5v after it starts that means that your alternator is not the cause of the low battery. If it stays below 12v when the car is running then there is a problem with the charging circuit. (Alternator)
I just went through this with both of my cars. My SUV ended up begin the alt. and my Pontiac ended up begin the battery. The above test is a quick way to diagnose a charge and load problem. A true charge & load test machine would be the best though.
If your battery & charging system test OK. It could be that you are in need of a tune up. Start checking your distributor cap, rotor, plugs & wires for wear or contamination. Also check your air filter to make sure it's not dirty and restricting flow.
justanything
Oct 11, 2010 02:12 PM
keepitngga1
Oct 16, 2006 02:03 PM
philkehn
13
Sep 7, 2006 03:58 PM
endlessdv
Oct 1, 2004 04:34 PM
OneFastLS
Jul 17, 2002 02:40 PM
