Fuel Filters
Old Apr 6, 2009 | 10:22 PM
syknxv3's Avatar
Default Fuel Filters
Its the last thing to do for tuneup on my 96 GSR, anyhow im in canada, so there are canadian prices, theres a $16 fuel filter and A $45 fuel filter, the latter being the wix brand, or would be good to save the $30 and get the cheaper one, its manhel or something brand.., and is it possible to do replace the fuel filter without disconnecting the pump underneath the rear seat.
Old Apr 6, 2009 | 10:49 PM
1Nsan3TEGRA's Avatar
Default Re: Fuel Filters
there is no need to disconnect the fuel pump to replace the filter. it is a fairly simple job. i believe the only thing you need to do is leave you gas cap open while doing it.
Old Apr 6, 2009 | 10:52 PM
martin21303's Avatar
New User
take ur gas cap off then unscrew tthe fuel filter.. you should try getting an OEM filter from the dealer thats the way to go...
Old Apr 6, 2009 | 11:14 PM
revn99teg's Avatar
theres no need for you to get the high volume fuel filters or anything expensive if you're just riding stock.
I know an Acura dealership that sells OEM integra parts for really good prices on ebay if you want to go that route. Search DCH Acura of Temecula. I can vouch for this guy. I've bought all of my OEM maintenance things from him.
Old Apr 7, 2009 | 10:58 PM
vinskint's Avatar
I have a Wix and I like it. oil filter too.. Wix makes good products.... No need to disconnecting the pump.... the fuel pump is off when the key if off... but there is still pressure in there not much but some.... there is a bleeder there to let off the pressure...
Old Jun 13, 2009 | 03:05 PM
imroadk1ll's Avatar
sorry for taking this thread but it did just help me out on whether to disconnect the fuel pump. is everyone sure about that though. also what is the spec of the fuel filter i went to walmart to check i thought itd b easy theres no book to tell you what size you should get
skaternak
Acura TL, RL & ZDX
May 26, 2011 07:04 AM
B18B EK
Sep 7, 2008 08:16 AM
prison_snitch
11
Jul 4, 2006 12:26 PM
CivilizedCiv
Aug 22, 2002 08:22 AM
