Dilemma Again
Alright so I had the same dilemma the first time around buying a header for my b16.
I settled on a Hytech Replica header which I really liked and was a very good header. The only problem is that clearance became an issue... to make a long story short they are almost flat now.
I opted for a solution by seeing if i ld get a skid plate made, but i was turned down twice because there was not enough ground clearance to clear the skid plate.
So the search begins again and i have a limited budget again $600 tops.
Two solutions are what I have come up with:
1. COMPTECH STAINLESS TIG WELDED HEADER
* Stainless Steel TIG welded 4-2 header
* 4-6 wheel HP gains
* 50 State Street Legal
$559.00
2. Edelbrock Ceramic 2-piece 4 into 1 Headers
- New Pro Flo 1-Piece Headers offer performance you can feel without taking a huge bite out of your wallet. In chassis dyno tests against a leading competitor's header that claims to maximize top end power, the Edelbrock 1-Piece Header beat the other guys' header by 3 horsepower at the wheels. Edelbrock Pro Flo 1-Piece headers for Honda/Acura have outstanding performance features such as mandrel-bent 1-3/4" primary tubes, heavy duty 3/8" laser-cut port flanges for a positive gasket seal and ceramic coated 16-gauge steel construction. Other advantages are lighter weight, better ground clearance and easier installation than competitor's 4-into-1 designs. They are direct replacements for stock exhaust manifolds, so installation is simple using the factory catalytic converter. 50-state emissions legal.
$359.99
has anyone ever used any of these two products? whch one do you think is the best out of the 2?
all comments are welcome!
$559.00
$359.99
if you cant make or find someone to make a shield for your header-
http://passwordjdm.com/PasswordJDM-A...P2196C462.aspx
The Narrow Headers have good clearance. It also WASTED the Hytech Replica headers in a dyno test.
I like that Armor plate thing, too. I'm going to look into that for myself!
Check out the Narrow's ground clearance:
the thing with that is that it has the same problem that the hytech has. the bour tubes bend under the oil pan... i dont want to take another chance with 500$ and waste it on something that will be destroyed.
So i'd really like to stay with something like the designs i posted above please!
thanks for the help so far.
and that header sheild i don't know if it would stop from denting the header
I also saw that Password:JDm makes an SMSP replica header that falls into my price range as well what do you think?
http://passwordjdm.com/Highend-Tri-Y...P2560C363.aspx
https://honda-tech.com/forums/showth...hp?t=2364945he quite makeing the toda replica's. even though it was a copy it was a nice peice made here in the usa. even the china stuff hurt him also
sjg88
May 31, 2017 07:11 AM
Cesare1987
44
Nov 25, 2005 02:07 PM
