anyone disconnect their ABS
Old Aug 14, 2002 | 04:40 PM
JDM nerbie's Avatar
New User
Default anyone disconnect their ABS
has anyone done this. is it better braking power. i have spoon calipers and want to know if this will help in brake feel/power?
Old Aug 14, 2002 | 04:42 PM
Hybrid ctr's Avatar
Default Re: anyone disconnect their ABS (nerbieR)
Read this thread
https://honda-tech.com/zerothread?id=249986
Old Aug 14, 2002 | 04:46 PM
erottik-R's Avatar
abs does not in any way affect the strength of the bakes. It simply allows you to maintain control during braking. Unless you are a professional driver, I will advise you to leave it connected regardless of the quality of the brakes.
Old Aug 14, 2002 | 04:50 PM
JDM nerbie's Avatar
New User
Default Re: anyone disconnect their ABS (Hybrid ctr)
that was some good info....thanks
i think i'll leave it alone
Old Aug 14, 2002 | 04:56 PM
Hybrid ctr's Avatar
Good choice
Old Aug 14, 2002 | 06:14 PM
slowassR's Avatar
Good choice
For sure. That would be very stupid to remove you abs. Even a awsesome driver would have a problem out breaking a abs system.
Old Aug 14, 2002 | 06:22 PM
baonest's Avatar
Default Re: anyone disconnect their ABS (slowassR)
mines not removed.. but the ABS light is always on.. its no prob, ive changed the ABS unit 2 times and nothin..
Old Aug 14, 2002 | 07:10 PM
ZygSpeed's Avatar
Default Re: anyone disconnect their ABS (baonest)
Mine should still be working, but I locked up the FR for a good bit (or at least it sounded like it),
during some heavy braking while coming back from lunch (after passing my friends TT-7 on a downhill/curved section).
Old Aug 14, 2002 | 07:16 PM
Edwin's Avatar
I kinda like (in a sick way) the bong noise you hear when the ABS resets.
Old Aug 14, 2002 | 10:45 PM
whtdc2's Avatar
New User
Default Re: anyone disconnect their ABS (Edwin)
I hate ABS
Old Aug 15, 2002 | 03:46 AM
DutchITR1689's Avatar
The ITR ABS is one of the best and it's programmable if you have the ABS computer. It engages very late (wheels lock up a bit) and very gently. If you have the shop manual (Helms) you can see why it's so good.
A normal ABS just reduces the brake pressure if one of the wheels locks up. And increase it again when it's turning again.
The ITR ABS estimates the vehicle speed with the 4 wheel speed sensors and controls each wheel's brake pressure (reduce, maintain or increase) so that the wheel speed matches the estimated vehicle speed within a programmable margin....
Old Aug 15, 2002 | 06:40 AM
nsxtcjr's Avatar
New User
Default Re: anyone disconnect their ABS (George Knighton)
Yes, leave the ABS alone.
For maximum braking, learn how to "threshold brake" - pressing the brakes just on the threshold of braking, but not actually locking up - in which case ABS won't activate. But, if you DO lock them up, ABS will kick in to allow you to keep steering the car.
ABS
thegeezerkid
Jun 18, 2008 10:24 PM
modulo_s
Aug 10, 2005 05:35 AM
fab
Jul 27, 2004 07:05 PM
C-Zero
11
Jul 27, 2004 10:31 AM
Tommy_Gunns
May 20, 2003 11:18 AM
