hydralic to cable need help.
Old Apr 6, 2009 | 11:29 AM
got00rice's Avatar
Default hydralic to cable need help.
i need help. i havent done this but im trying to find some infomation on this first. i got a 91 civic si hb which i just bought. i know its a cable car but i would like to just convert everything over to a hydralic (obd1) so would everything just be a plug and play if i get the hydralic mount conversion and obd1 wire harness? and one of my concern is the speed sensor plug. the cable has the cable that goes into the tranny but the hydralic has the plug, so do i have to change any of that? well if u can help me on this it'll be great. thanks guys
Old Apr 6, 2009 | 11:36 AM
nico91civic's Avatar
Default Re: hydralic to cable need help.
you can swap the vss's you need the cable operated one unless your swapping the cluster, ive never done it but to use the 94+ teg cluster you drop an electric vss into the cable trans so it should work the other way too. sorry cant really help you with the obd1 stuff i have no clue about converting that stuff. also if your doing a hydro/cable clutch conversion you might want to check this out https://honda-tech.com/forums/showth...ighlight=sonem
its a little more complicated install but from what i hear cable operated hydro clutch sucks so this is a true conversion setup no cable period
Old Apr 6, 2009 | 08:20 PM
1904wrencher's Avatar
just change the speedometer. So you don't have to rewire stuff.
Old Apr 6, 2009 | 08:49 PM
got00rice's Avatar
so if i customize a different cluster gauges into the car i should be fine right? anyways thanks guys for the help.
Old Apr 6, 2009 | 08:53 PM
You don't need to change your cluster. Just change the sensor and re-soder the reverse light harness and that is it.
Old Apr 6, 2009 | 09:02 PM
got00rice's Avatar
thanks for the info.
Old Apr 6, 2009 | 09:14 PM
yeah i guess i wasen't to clear by no means would i suggest a cluster swap just to have a hydro trans, that would be foolish
Old Apr 6, 2009 | 09:35 PM
Also you need the mount and hardware to convert it to hydro. I hope you have that all ready. Don't trip brother.
Old Apr 7, 2009 | 09:53 AM
got00rice's Avatar
yea i know u neeed to have the tranny mount conversion. cause im planning to do the swap to my ef. but just wannna get some info on it before i started. thanks for all the help guys.
Yodi71
Feb 11, 2019 12:21 PM
crxblues
Dec 6, 2006 10:44 AM
philkehn
Nov 19, 2006 10:08 AM
IhEARTjDM2
Oct 24, 2005 02:39 PM
HondaDreamz
Jan 11, 2004 09:36 AM
