first gen crv rear disk .....
so i found me a crv and gong to pick it up soon (hopefully) and i was woundering if the is a way to do a rear disk brake conversion??
would the integra type r rear trailing arms work ?
Integra ZXi trailing arms. Rear discs and support for the RT-4WD rear hubs (to accommodate the drive shafts), as it was an RT-4WD car stock. Should be "plug and play" for the most part.
The real question is, why? The drums are lighter than discs and provide more than adequate braking for the rear of the vehicle.
Do you know what brake bias is and what happens to it when you start changing major braking components? Rear discs are very likely going to require an adjustable prop valve if you want your car to brake like a normal car...
yes i know that it would require the right prop valve for it to brake normally. i just want to know if any one has done a rear disk conversion on a first gen crv.
fitseries3
Honda CR-V & Element
Jun 8, 2012 04:47 PM
db1b18c
19
Mar 8, 2010 03:39 PM
TypeSH
Feb 5, 2003 08:38 PM
