D-Series Manifold w/ T25 flange?
Looking for a D-series manifold that has a T25 flange on it. HKS no longer carries D-series manifolds for SOHC motors. Any suggestions on which manifold to look at and prices/links?
I have an HF manifold right now but I'm having a little trouble getting an adaptor plate made. Does anyone have an adaptor for sale, if you reccomend using my HF manifold instead of a new one?
My plans are no more than 10 PSI of boost, not sure if that might help make a decision. Thanks!
Nick
Nick
Well the HKS t-25 manifold had a JDM T-25 flange on it. So a DSM T-25 turbo would not bolt to it. The JDM T-25 turbo is based off the SR20DET. its a rectangular flange similar to the T-3.
No one makes a D-series manifold with a DSM T25/14b Flange. Gary and Randys website sells adapter plates for HF to DSM T-25's I think they are 80 bucks.
http://thenew.gamesbbs.com/~turbosi/
Jeff Frank
http://www.homemadeturbo.com
Jeff Frank
The Apexi and Greddy SOHC manifolds both have your conventional Garrett Style T25/T28 flange.
The DSM Flange looks like this
Which is a circular flange.
again, the 14b and USDM DSM T-25 turbo does NOT bolt to any manifold, unless someone custom makes it.
Jeff
How much does an SFP manifold cost? And are they any good?
What about the drilling holes method? Sounds pretty ghetto to me? Anyone done it? Does it work?
Nick
Nick
SFP TURBO MANIFOLDS PRICE LIST
DESCRIPTION
Honda CRX D15 SOHC With T-25, T-3, or T04 Flange (Log Type)
Standard, No External Wastegate $375
With External Deltagate Flange $400
With External HKS Flange $425
Honda Civic D16 SOHC With T-25, T-3, or T04 Flange (Log Type)
Honda Civic B16 DOHC With T-25, T-3, or T04 Flange
Standard, No External Wastegate $425
With External Deltagate Flange $450
With External HKS Flange $475
Acura Integra B17 V-TEC With T-25, T-3, or T04 Flange (Log Type)
Acura Integra B18 V-TEC & Non V-TEC With T-25, T-3, or T04 Flange
DESCRIPTION
hmm im wondering if you can just drill holes into the turbo flange itself...so it will line up with the hf manifold.
Yup.....
I will have my "Junk Yard Turbo Buildup" page done sometime next week....
I will have lots of pics....and some info on how to do this....
8 months of daily driving, and NO problems.
i had the same problem when i put together a shopping list for my turbo parts i went to hks and said i need all this.....so i got eveything, then i took it over to the motor shop and had the manifold ported and thermal coated,
then i go to put it all together and the DAMN manifold is for a B series.....well atleast i have a manifold for my next motor
so i called hks and they got me in touch with revhard, and they made me a manifold, just had hks send over the t3 flange and they welded it onto the manifold
