Want to install a Fuel cut off switch
Was told it was pretty easy. I want to hide it, but not too sure how to start?
Havent gotten down there yet, but do you guys have any tips? Can a normal switch do the job? I keep reading about a relay.
yes you can splice it to a switch but if you run the switch more than 2-3ft then you need to use a relay.
i would prefer to use a relay because it expands your options of where to put the switch.
I got a 3 connector switch.
Im a little new to this, but what would the 3rd connector be?
One for the "Ground", One "positive, and One "Negative"
I know I should pay someone for this, but I honestly don't even trust ANYONE near my car. Just over protective :-(
Here is a picture of the cables to the fuel pump.
Can anyone help me out to pointing which one is which? *There might be some different cable colors under those too. I didn't think the fuel pump had so many colors!
Found everything by taking 30 mins of my life.
Def worth it. Thanks guys.
https://honda-tech.com/forums/audio-security-video-27/%5Bhow-%5D-car-security-1794938/
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
my_slow_civic
12
May 9, 2005 07:08 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
