running my car what out a knock sensor?
Old Apr 4, 2009 | 08:25 PM
j me4door's Avatar
Default running my car what out a knock sensor?
i damage my knock sensor takin the motor out a othe vehicle.. will my car run funny what a out a knock sensor?
Old Apr 4, 2009 | 10:16 PM
waaBAAH's Avatar
Default Re: running my car what out a knock sensor?
cel will be on but i dotn think it will run any diffrent
Old Apr 5, 2009 | 02:30 AM
trustdestruction's Avatar
CEL will be on... may or may not put you in limp mode... not sure.
Old Apr 5, 2009 | 04:00 AM
Jimster480's Avatar
depends on if your car is OBD2. If its the top knock sensor on an OBD2 car it will put u in limp mode.(no vtec and retarded timing past 4k)
Old Apr 5, 2009 | 02:26 PM
buff1110's Avatar
get your ecu chipped and have them disable knock. i highly recommend phearable.net
Old Apr 5, 2009 | 02:48 PM
Murk 'EM's Avatar
just put in a new knock sensor.. its there for a reason
Old Apr 5, 2009 | 03:06 PM
ifIexplode's Avatar
Why go through all that?
Find a used Knock sensor in the marketplace or craigs, If the motor is out it will be cake to change.
Old Apr 5, 2009 | 03:16 PM
NightCat's Avatar
CEL will probably throw a 28.
Old Apr 7, 2009 | 06:37 PM
Jimster480's Avatar
if its the secondary knock sensor (which I assume it is because he broke it putting in the motor) then its a piece of cake to install even when the motor is in.
@OP I suggest you go to a junkyard or go on CL and pick one up cheap, or look on HMP somebody has got to have one lol.
RoB316
Apr 20, 2007 03:39 AM
ELSUICIDA
Apr 15, 2007 05:13 PM
Hockey27925
Nov 18, 2005 05:10 PM
shadykit
18
Mar 14, 2005 12:51 PM
