Can't get tranny to budge!
Old Apr 4, 2009 | 08:24 PM
EKris's Avatar
Default Can't get tranny to budge!
I was hoping to get my longblock in my car pulled out today so I could trade with a friend, but ran into a problem. I cannot get the longblock to "seperate" from the tranny. I removed all the bolts that are holding on to it. The front half of the longblock to tranny is "seperating" but the rear half is not budging or cracking away from eachother. Tried to pry it off and many other things, but still a no go. Anyone have any suggestions?
Old Apr 4, 2009 | 08:56 PM
mxracer420's Avatar
Default Re: Can't get tranny to budge!
i had this same problem check there is one bole on the backside of motor its located right above where the driver side axle will hook in. took me forever to find it and once i undid it the tranny pulled right off. i had the exact problem lol
Old Apr 4, 2009 | 09:18 PM
UserX826's Avatar
also make sure the torque converter and flywheel plate are off..
Old Apr 4, 2009 | 09:30 PM
forcefedferio's Avatar
dumb question but is the T-bracket out of the way for the rear motor mount?
Old Apr 5, 2009 | 06:54 AM
94EG8's Avatar
Seagull Management
If you removed all the bolts it would have seperated. There are a couple of easy to miss bolts on the back side of the engine and tranny. Also one of the starter bolts has to be removed, it goes through the bell housing and threads into the block.
Old Apr 5, 2009 | 07:12 AM
EKris's Avatar
^ I didn't remove one bolt from starter. I guess that might be the problem. I Removed the T bracket as well.
Alpinestar03
May 11, 2007 04:26 PM
jikespingleton
Dec 20, 2006 07:22 PM
triggerX
Apr 24, 2004 12:03 AM
h2point2
Apr 16, 2004 12:17 PM
roydogg
Aug 19, 2003 10:55 PM
