Can bad bearing cause caster problem?
Old Apr 4, 2009 | 06:42 PM
tienzien's Avatar
Default Can bad bearing cause caster problem?
Hi, just like the title state, can a bad bearing cause caster problem? This happen recently when I noticed that my wheel is shifted closer to the rocker panel area. This car hit a curb before and after that accident, that's how it looked like, but I replaced the traction bar and LCA. After I replaced it the wheel was centered until just recently. I tried jacking it up and shake the wheel there is no movement. However there is play when the car is on the ground and I shift the wheel left and right. The wheel also shift back to the center when i reverse and make a stop without moving forward. so I believe there is play in there. I took the wheel out to check all my bolt and give everything a good tug, everything is on tight. Now I'm stumped please let me know if you have an idea of what's the problem.
Old Apr 4, 2009 | 06:45 PM
steveo135's Avatar
Default Re: Can bad bearing cause caster problem?
i highly doubt that a bad bearing is the cause of your problems... since it moves back and fourth from center maybe the bushings are horribly bad?
Old Apr 4, 2009 | 06:50 PM
93formula's Avatar
check your ball joints.
Old Apr 4, 2009 | 09:42 PM
tienzien's Avatar
I will look into the ball joints and bushing and replace if necessary. Are there other possibility that I can look into if those are not the cause. Thanks for reading.
alscrx
18
Jul 26, 2009 10:51 AM
95BoostedEJ1
Nov 14, 2008 01:49 PM
B18c1_turbo
Mar 14, 2008 10:43 AM
LoserKid
Suspension & Brakes
Aug 18, 2005 09:15 AM
OneThirtyEight
Oct 30, 2001 06:03 PM
