94 Civic...Heater Core question...
Old Apr 4, 2009 | 06:32 PM
Black Diamond's Avatar
Default 94 Civic...Heater Core question...
So here is the deal i just purchased a 94 civic ex coupe and was testing everything out and it doesnt blow warm air. So is it the Heater core or what is it...If it is the heater core then were is it located and what should i expect to pay on one..
Thanks im new to the Import scene so be nice...
Thanks Alot
Old Apr 4, 2009 | 07:00 PM
hexjunkie's Avatar
Default Re: 94 Civic...Heater Core question...
unless your car is full of coolant it probably isn't the heater core
I would check to make sure the switch is actually connected to the actuator arm (or in older cars its a lever assembly) behind the dash.
The heater core is a small radiator like device that sits inside the firewall behind the dash that coolant passes though. When you flip the switch for hot air a vent opens to push air across the front of the heater core and then into the vents. This is what creates the warm air... generally if there is no warm air blowing after the car warms up there probably is no airflow across the heater core (which is why i mentioned what i mentioned above)
Old Apr 4, 2009 | 07:04 PM
Former User's Avatar
Yeah, don't consider a bad heater core until you know coolant is topped off in the radiator, the cooling system is bled, and the coolant valve on the hose leading into the heater core is open.
Old Apr 4, 2009 | 07:07 PM
cloudconnected85's Avatar
um ok, check the valve that is on the hose that runs into the firewall to the heater core make sure it is opening and closing all the way. make sure coolant is bled. and i once pulled the hoses off the heater core and flushed it with a water hose, helped me but i don't know what others might say to it.
Old Apr 4, 2009 | 07:16 PM
Thanks i will have to give that a try..i did some research and just came to the conclusion the heater core was the problem but i will look into it tmmrow...And the coolent is to the top..so it must be a line or th heater core wouldnt you think..?
Thanks Blackdiamond
EJ8_Man
Oct 28, 2010 04:38 PM
cruleman
Honda Civic (2001 - 2005)
Oct 1, 2006 12:05 PM
B16 IIgen
Sep 7, 2006 11:07 PM
twentyhurtz
Mar 31, 2006 06:47 AM
misledyouth_is_back
Dec 15, 2003 08:09 AM
