MAC boost solenoid acting up
Old Apr 4, 2009 | 04:33 PM
EJ8chu's Avatar
Default MAC boost solenoid acting up
Ive had the MAC boost solenoid wired up in my car through S300 since November. Worked flawlessly for 4 months. Helped my turbo spool up a little quicker and all. So recently, I pulled my motor out, and did some work cleaning up the bay. I have the solenoid mounted to the body of my car so all i had to do was pop the 2 lines off. I left it plugged in at the solenoid, but i cut the power and ground wires off inside the car because of how i had it ran. The car was out of commission for i guess 2 weeks or so. Hooked everything up EXACTLY how it came apart. Have not changed a single thing.
I have changed nothing in the parameters. I'm thinking the solenoid might be bad. Anyone else had any issues with the MAC solenoids?
Old Apr 4, 2009 | 07:31 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: MAC boost solenoid acting up
nope not me. ive always found it to be some type of wiring issue that a person has missed.
It was a guy on here and he went on vacation came back and all of a sudden it didnt work. Ended up being his connections.
Old Apr 4, 2009 | 08:09 PM
locash's Avatar
I've used a lot of them, no problems here either.. About the only thing I see wrong is the vacuum/boost lines..
Old Apr 5, 2009 | 07:31 AM
EJ8chu's Avatar
Im thinking its in the wires. Im going to ohm out each one in the next day or so.
Old Apr 5, 2009 | 07:40 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i put money on it. yeah i could not understand the way your vac/boost lines
Old Apr 6, 2009 | 04:28 PM
mtber's Avatar
I have a vacuum diagram on http://www.phearable.net/tech
I hope it helps.
Old Apr 8, 2009 | 04:51 PM
EJ8chu's Avatar
That's they way Ive had it hooked up since day one. Just for reference, is that diagram showing normally open for closed operation?
Old Apr 8, 2009 | 04:58 PM
mtber's Avatar
Open
Old Apr 12, 2009 | 06:47 AM
EJ8chu's Avatar
i figured. thanks for the help
guy_from_nerk
Aug 8, 2011 07:03 PM
justinCO
May 20, 2009 06:11 PM
B18EG6
May 16, 2008 08:02 PM
IntegraTypeR
May 5, 2008 01:31 AM
