dpfi to obd1
Old Apr 4, 2009 | 04:01 PM
gastonmrod's Avatar
Default dpfi to obd1
i bought a 89 civic dx sedan pics up soon. i converted the d15b2 to obd1. changed the intake manifold to a y8 and installed a t3t4 57 trim turbo. i order the etd traction bar and swaped the radiator to a eg. I'm planing on swapping the d16z6 i just bought after i re ring the motor. i started the car and it runns ok but the idle dropps below 200rpm. i still havnt installed the o2 sensor. and am using a po5 ecu. i plan on having the ecu converted to a p28 and chipped. does any one know y the idle falls so low. also is does the charcole cannister have to be connected.
Old Apr 4, 2009 | 04:13 PM
tkda's Avatar
Default Re: dpfi to obd1
did you rewire for the mpfi? if not then you are running on 2 of 4 cylinders.
o and that p05 shouldnt even run your mpfi motor. espesially since you say its obd1.
Old Apr 4, 2009 | 07:02 PM
gastonmrod's Avatar
i rewired the car with the boomslang wire harness. installed a obd1 dis and rewired the injectors. the car runs find while its not idling.the car when its cold starts perfectly fine and runs great, after a while it starts to idle low.
Old Apr 4, 2009 | 07:51 PM
93formula's Avatar
http://www.hondata.com/techecuid.html
the p05 is obd1, will work fine, have you adjusted the idle yet? is the y8 manifold a auto or manual?
Old Apr 6, 2009 | 06:16 PM
gastonmrod's Avatar
the y8 is manual. as soon as i turn on the car it idles at 2000rpm and after driving it the idle will not stay stable at 700 rmp it is well belowe and even turns off
tuname420
Dec 12, 2007 10:49 PM
rice is nice
Mar 29, 2006 03:54 PM
civiclxb16a
May 2, 2005 04:11 PM
JDM96SpecCTR
Nov 14, 2004 04:36 PM
bbb18c1
Jan 12, 2003 01:40 PM
