my b18 build up...i need help
Ok i was out wheeling with my buddies and we came across this acura integra in a field and i didnt think much of it so my buddy was crawling on the car with his jeep and for the hell of it i decided to pop the hood and when i did i saw a nice little B18a1 sitting in there so the next day i went up with my truck and pulled the motor out right in the field. It has 197k on it and i was in really good shape here it is striped
ok well my first plans are to get the deck level, cylinders honed, and crank balanced(if i use the stock crank) and everything cleaned up nice. as for the build i am kinda lost this will be my first import build. here is my parts list i am really looking to be sitting in the 200whp range
B16 head
Skunk2 intake manifold
stock injectors and TB/ prob. bigger injectors with walbro fuel pump
Skunk2 cam gears
stock 3 layer headgasket
cold air intake
MSD cap and coil
not sure on valves, springs and cams?
B18A1 block
stock ls rods with arp rod bolts
stock ls crank balanced
Not sure on pistons and rings or rods/ mabye new stock ones
B16 head
Skunk2 cam gears
cold air intake
MSD cap and coil
B18A1 block
BlackEG6
Jul 13, 2006 06:54 AM
importboi22
Dec 3, 2005 11:05 PM
austrian type-R
Apr 13, 2004 07:04 AM
