Car has been down for some time, now boosted & won't start
Old Apr 4, 2009 | 02:36 PM
Trojan Man's Avatar
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
Default Car has been down for some time, now boosted & won't start
I'm just trying to get some ideas. I didn't stay around and play with it much today so it could be something minor or something I did wrong.
My car has been sitting for quite some time now (over a year)... I got it boosted and now it wont turn over. It will get spark & crank but it just won't turn over. I primed it about 5-8 times & then tried to turn it over. You could hear it wanting to turn over but it just wouldn't.
I put fresh oil in it, fresh gas and all that good stuff. I figured it would take a minute for the fresh gas to go through the system, I tried cranking it about 15 times, each time it would crank it would slowly get better as it was wanting to turn over but I just didn't want to get to excited with it and crank it 340697390457 times and possibly **** something up.
My battery was dead as a rock so I took the battery out of my friend's Integra & put it in mine. It seemed to work all my audio components just fine so I don't think that's the problem. He did say though that it wouldn't start his project EF but it starts his daily driven Integra just fine. Weird.
The car has a stock fuel pump, stock injectors & a stock P28 with a Boomslang OBD2 to OBD1 harness.
I know this is very vague, so start asking away and I will answer to the best of my ability.
Thanks.
Old Apr 4, 2009 | 05:35 PM
p2592b's Avatar
Default Re: Car has been down for some time, now boosted & won't start
Was that gas sitting in there for over a year? If so drain that out and get some new gas and try.
Old Apr 4, 2009 | 05:38 PM
Trojan Man's Avatar
No Sales Forums
Thanks.
I drained it prior.
Old Apr 4, 2009 | 05:52 PM
Redcoupe's Avatar
Junk the ecu.
Put your obd2 one back in there and try it.
I'll put money on it being a bad chip of dead soldier.
Also, that boomslang harness brand new? I'll never buy a used one because the pins come out when they've been abused.
Your thermostat ground hooked up?
Old Apr 4, 2009 | 05:53 PM
Crx Jimmy's Avatar
just turn the ignition to the on position ten times or so and wait till you hear the fuel pump prime then turn off and back on again, just to make sure the old gas is out of the lines. also if possible use the harness and ecu on a friends car to rule out either as a problem. also it couldnt hurt to put new plugs in it. you also might have to open the throttle a bit when cranking
Old Apr 4, 2009 | 05:57 PM
Trojan Man's Avatar
No Sales Forums
Originally Posted by Redcoupe
Junk the ecu.
The ECU is off my old 95 Civic Coupe that was SOHC Turbo. It was this P28 running with emanage. I'm positive this ECU works. This ECU is not chipped either.
The harness is out of Shawn's Si.
I'm almost positive, tranny has never been pulled but I'll check tomorrow.
I will try to get OEM plugs or barrow a friends. Honda is closed on Sunday.
Old Apr 4, 2009 | 06:20 PM
Redcoupe's Avatar
Toss some NGK 7's in there.
And trust me. Shawn pulled my harness out my car and we went to plug it back up and my harness was FUBAR'd. Beezy is STILL repairing it.
Old Apr 4, 2009 | 06:55 PM
Joseph Davis's Avatar
Transmissions have nothing to do with thermostat housing grounds.
Old Apr 4, 2009 | 06:59 PM
Trojan Man's Avatar
No Sales Forums
Reading owns me.
Old Apr 4, 2009 | 10:23 PM
lookout22's Avatar
did you use a test light to confirm that you are getting spark? pull the fuel line off and make sure gas is comming through. Also try testing your map sensor and knock sensors
Old Apr 5, 2009 | 01:35 AM
black_EM1's Avatar
Community Builder
Community Influencer
Kind of a random question, but are your sensors hooked up correctly? i.e., MAP, IACV, etc.
Also, have you tried the stock ECU?
And lastly, stock fuel pump?
Old Apr 5, 2009 | 04:42 AM
Trojan Man's Avatar
No Sales Forums
No reason for gas not to come through, but anything is possible & I'll check today. Thanks.
Sensors are OK, they weren't touched but I'll go over all of them again today just to double check.
Stock ECU is sold because I know this P28 works.
Stock fuel pump was just to get it started. Walbro is in my room along with my clutch and all that good stuff that I'm going to install after I get it running.
Thanks Charles.
Old Apr 5, 2009 | 07:32 AM
black_EM1's Avatar
Community Builder
Not a problem Kyle. I want to see this thing on the road.
Well video of it, I guess.
Old Apr 5, 2009 | 08:53 AM
Trojan Man's Avatar
No Sales Forums
I thought about that, so I have one uploading right now on YouTube. I'll host it when its done. I have a friend over right now that works at Honda trying to mess with it. I'm clueless.
Old Apr 5, 2009 | 09:17 AM
Trojan Man's Avatar
No Sales Forums
http://www.youtube.com/watch?v=ONr5kwX3DwA
Old Apr 5, 2009 | 09:52 AM
tagperformance's Avatar
why does your motor jump around like that when your trying to start it maybe need new mounts. 1. check and verify that your getting fuel and spark. 2. make sure the map sensor and tps aren't mixed up. 3. check all of your fuses. 4. also check your distributor and timing.
Old Apr 5, 2009 | 10:45 AM
accord_raffi's Avatar
It is priming when it goes you turn the ignition to the "on" position correct?
Old Apr 5, 2009 | 10:54 AM
LightningTeg's Avatar
Community Builder
Even if the map sensor wasnt plugged in it would start and just run shitty.
Change the plugs, make sure the fuel pump is priming.
Old Apr 5, 2009 | 04:26 PM
Trojan Man's Avatar
No Sales Forums
I'm keeping my options open and keep trying new things each day.
Old Apr 5, 2009 | 05:04 PM
marcj's Avatar
do a barrel roll!
Old Apr 5, 2009 | 08:04 PM
Redcoupe's Avatar
Man check timing just incase some retard took your dist. off and didn't put it back on correctly.
Old Apr 5, 2009 | 08:12 PM
Brain909's Avatar
Check the main relay
Old Apr 6, 2009 | 05:48 AM
SilverEk3dr's Avatar
prob fowled your plugs out. Put new ones in.
Old Apr 6, 2009 | 05:54 AM
AfTeRhOuRs209's Avatar
Originally Posted by marcj
do a barrel roll!
Old Apr 6, 2009 | 04:46 PM
Trojan Man's Avatar
No Sales Forums
With a friend's battery & I believe the same ECU and jumper harness or a friend's jumper harness & a JDM GSR ecu. I didn't even look at it at the time.
It's def. getting gas. Everytime I try to turn it over, that's all I smell. I'm checking spark tomorrow.
http://www.youtube.com/watch?v=49GmE9ECO6o
dthor68
Honda CR-V & Element
May 4, 2018 10:33 AM
2000integls
Oct 6, 2009 11:14 AM
DC206R
Jun 11, 2009 09:00 PM
Muckman
Oct 4, 2006 08:20 AM
Audio28
Jul 3, 2003 05:33 PM
