how-to add a footrest / dead pedal into a civic or crx PICS
here's a little how-to... im sure there are other ways to attach the foot rest on but i wanted a permanent oem-like solution.
anyway i been driving my civic more then my crx and i really miss having a footrest...
my civic did not come with a footrest but my crx did. so I was curious if I could put one on the civic, so I pulled the carpet aside on my civic and compared it with my crx and its identical! but its missing those 2 bolt studs.
I drilled 2 holes (between the dimples) and put in 2 bolt heads into it, the fit is snug. I then put 2 spot welds on each bolt head. The top hole goes into the wheel well (you can see light thru the hole, in the first pic below) so after I did the spot welds, I smeared silicon sealant over bolt heads to keep it sealed. the firewall/carpet padding had a perfect outline of a cutout for the footrest too. also made small incisions on the carpet for the studs, bolt it up and done.
enjoy
enjoy
I know the STDs do not have them. The Dx might... i will check soon.
I always wanted one of these though... Now I have to track down an oem footrest!
