Will a bad intake manifold gasket cause smoke?
Old Apr 4, 2009 | 09:40 AM
buddy190's Avatar
Default Will a bad intake manifold gasket cause smoke?
I know theres a coolant passage that goes through the intake manifold, but could coolant make its way into the intake charge through a leaking IM gasket?
Old Apr 4, 2009 | 09:41 AM
TEAM JDM-P's Avatar
Default Re: Will a bad intake manifold gasket cause smoke?
yes it will it will leak from the passage way into the intake ports them selves
Old Apr 4, 2009 | 09:43 AM
TravisCadello's Avatar
yes it will, lol i didn't know this untill i thought id reuse my intake mani gaket and ruined my oil with water.
Old Apr 4, 2009 | 09:46 AM
buddy190's Avatar
I guess I should cross my fingers and hope this is the problem, then.
Thanks for the reassurance.
Old Apr 4, 2009 | 09:49 AM
one easy way to find out is take off your headers and start it for 3 seconds and turn it off and if the cyl all the way left is the only port with a little water comming out then its ur problem forsure.
i found this out the easy way cause my ebay headers were cracked their on all 4 ports lol and i seen it drippen water.
Old Apr 4, 2009 | 09:50 AM
it will only get into one cyl not all 4.
Old Apr 4, 2009 | 10:35 AM
civichb95lnd's Avatar
If the IM gasket isn't the problem the next step would be a leak down test to find out if the head gasket is bad.
Old Apr 4, 2009 | 01:12 PM
buddy190's Avatar
The head gasket was bad. I had it replaced with a Felpro mls gasket, so it should be good for a while.
Im flabbergasted that the motor is in the shape it is after 89,000 miles... Yea... flabbergasted is the word.
I think the previous owner tryed to replace some gaskets himself and didnt exactly know what he was doing. Im pretty sure the motor never over-heated, though. When I drove it home(over 90 miles), it had NO coolant in the radiator, just air, and it never went above operating temp.
Maybe that was a sign its meant to be lol
Old Apr 4, 2009 | 03:57 PM
fastrxu's Avatar
did you machine the head/ check for warpage? just checking
Old Apr 4, 2009 | 05:31 PM
buddy190's Avatar
Its not warped
Old Apr 6, 2009 | 05:25 PM
buddy190's Avatar
Bad news, everybody... not that you care
Cylinders 1, 3 and 4 are burning coolant. Maybe oil too. Its too late to call around, but do most franchise shops do leak-down tests?
Old Apr 6, 2009 | 05:29 PM
daam,man u got the best of luck just like me.
Old Apr 6, 2009 | 05:32 PM
maybe its warped or bad head gasket. yea most mechaics should do it. but people told me mechanics thought a leak down test was a regular compression test. so make sure and tell them. and let me know how much they charge cuz i need it done to.
Old Apr 6, 2009 | 05:38 PM
buddy190's Avatar
I though I was being so smart buying this hatch. "The body is in great shape, and all it needs is a head gasket," I thought. ****ing car is a money pit from hell. I guess I really cant complain too much though. In total, ~700.00 has been spent on the car, including the price of the car its self.
Old Apr 6, 2009 | 05:47 PM
lol not bad. yes my Honda is a Money pit also. but not as bad as my Ford Probe was. i had Well Over 8k into it.
looks like you'll be taking that head back off and getting it shaved.
Apex1972
Mar 11, 2010 11:14 AM
disturbedinwv
Nov 6, 2009 09:18 AM
chu77
Jul 25, 2006 05:03 AM
Jowee
Nov 18, 2005 10:07 AM
EF4lyfe
11
Aug 27, 2004 12:23 PM
