T4 Twin Scroll Collector
Old Apr 3, 2009 | 08:45 PM
SpeedFactoryFab's Avatar
Default T4 Twin Scroll Collector
I have received a few PM's and messages in regards to twin scroll/divided inlet collectors for T4 turbochargers, wondering how to make a true T4 divided collector. Well, I started working on the manifold for one of our shop's race cars today. We are using the Borg Warner S372R turbo, with twin TiAL gates. So far I only have the collector built, I took a few photos to share with all of you. I hope these help give you ideas. Im curious to see other T4 collectors anyone else has built, post them up if you have them!
Old Apr 3, 2009 | 09:14 PM
FaceTuned's Avatar
Default Re: T4 Twin Scroll Collector
looks F*cking good
what amps do you weld at?
Old Apr 3, 2009 | 09:34 PM
JDM KID 510's Avatar
Nice.
Old Apr 3, 2009 | 11:27 PM
Set for 160A, pulsed
Old Apr 4, 2009 | 01:09 AM
vectorsolid's Avatar
HOLY CRAP, that's sweet!
Old Apr 4, 2009 | 05:26 AM
d16sandrail's Avatar
tell the truth...you don't really get a lot of PM's about these, you just wanted to show it off because it looks resickulous :-)
Old Apr 4, 2009 | 06:20 AM
m R g S r's Avatar
I think if theshodan sees the title of this thread he's gunna be angryyyy
It's divided housing
Nice welding thou
Old Apr 4, 2009 | 06:49 AM
RC000E's Avatar
I can't imagine people having a hard time with these divided collectors cause they're cake versus a 4-1. I agree...I think you just wanted to be a show off.
Old Apr 4, 2009 | 06:55 AM
AutoSelectTuning's Avatar
Good job, Looks like a mint piece.
Old Apr 4, 2009 | 06:58 AM
honda_junk's Avatar
looks good..
what filler rods do you use for ss to ss and mild steal to ss?
Old Apr 4, 2009 | 07:19 AM
Agtronic's Avatar
The welds on that collector are really nice! That's some very clean work!
I have made a few, I basically make two 2-1's, then cut them at a slight angle, then crush them so they fit the opening, then weld ...
edit : Removed pics, don't wanna high jack!
Old Apr 4, 2009 | 08:25 AM
Agtronic- That is exactly how I made it also, thanks for the post pics. RC000E-You're right, a 4-1 is much more difficult, but for most it is also much more common to build. I wanted to show something that is not an everyday piece. Honda_junk- 309L filler flange to pipe, 308L pipe to pipe
Old Apr 4, 2009 | 09:27 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
very nice....clean welds
Old Apr 4, 2009 | 09:30 AM
honda_junk's Avatar
what size is the filler rod?
Old Apr 4, 2009 | 10:03 AM
DisEpyon's Avatar
I think he is using a 3/32 size filler rod for tube to flange and maybe a 1/16 filler rod on the tubing only for the tight spaces.
very nice welds, be nice if you could inform us on your set up specs.
Old Apr 4, 2009 | 11:02 AM
tepid1's Avatar
VERY nice work SpeedFactory. I wish I could weld like that....
Old Apr 4, 2009 | 02:23 PM
got wide's Avatar
i wish i still had pics to post of mine but when i made my collector for my divided mani i made it just like a 4-1 but actually welded in a flat divider to separate the two sides. the way you guys have done it looks good and should work fine also, but i think with a divider between them, the two sides fit the holes in the flange a little better.
Old Apr 4, 2009 | 07:16 PM
ScorpionT's Avatar
SFF, very nice work!
Old Apr 5, 2009 | 06:55 AM
onefstek's Avatar
Not bad suka. Keep it up.
Old Apr 5, 2009 | 07:56 AM
RC000E's Avatar
I was just messin with you man. Divided's are pretty nice to make versus 4-1's though, I must say.
Look at Agtronic with his little photo booth...hahahaha
Old Apr 5, 2009 | 02:24 PM
JDMCRX's Avatar
How do you guys get down so close in the runners. do you just pull the tung out like over a inch??
Old Apr 5, 2009 | 05:01 PM
Agtronic's Avatar
That was supposed to go on the online store, that's why I have so many pics like that ... Not trying to be cool or nothin' ehehe ...
Old Apr 5, 2009 | 08:17 PM
weiRtech's Avatar
OG Fabricator
you'll have to change your name to markkool.
Old Apr 5, 2009 | 11:15 PM
DisEpyon- yes, 3/32 filler for the flange to pipe, 1/16 for the pipe to pipe, and in some of the reallly tight spots, .035 308L filler. JDMCRX- major tungsten extension Got Wide- I've actually done that too, I had it all mocked up but I wasn't happy with the way it fit together versus this type, but I didn't spend much time on it. That's awesome someone else did that too! hahaha
Old Apr 7, 2009 | 12:29 AM
DisEpyon- yes, 3/32 filler for the flange to pipe, 1/16 for the pipe to pipe, and in some of the reallly tight spots, .035 308L filler. major tungsten extension
I've got a question for the fab guru.
I'm running a Weldcraft CS310 water-cooled torch (this one)
http://cgi.ebay.com/Miller-Weldcraft...18124005r22436
on my Miller, off a foot control. I'm tied to the weld table and want to get out and under stuff.
What would you recommend for a torch and trigger to get away from the table. There's so much stuff out there, that frankly, I'm not sure what to get. Do you have a favorite or a "go to" torch you find yourself using more often?
Any help appreciated.
