Help: Radiator Fan not Turning On
Old Apr 3, 2009 | 03:59 PM
white98gs-r's Avatar
Default Help: Radiator Fan not Turning On
my cooling fan won't turn on after i replace a heater hose. i checked relay it's fine. hook up the fan to the batter it's fine. hook it up through the connectors and it's fine. it did over heat due to insufficient coolant but after i add more coolant it's fine. the fan won't turn on five-ten minutes after the car reaches normal operating temp. it seems like there's a lot of pressure because smoke starts to leak through the rad cap 5-10 mins after normal temp. what can this be water pump, thermostat, etc. any help is appreciated
Old Apr 3, 2009 | 04:51 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help
It could be the fan switch. A meaningful title will really help your cause.
Old Apr 3, 2009 | 11:18 PM
Default Re: Help: Radiator Fan not Turning On
thanks for adding more to the title. will check that tomorrow. any other help will greatly be appreciated
Old Apr 3, 2009 | 11:51 PM
wunfstgsr's Avatar
Loved
Community Favorite
im leaning tward the thermostat it could of gone bad when it overheated not to common but maybe it has a leak in the gasket this would need you to drain all coolant and check the thermo or replace if you like then bleed the radiator just let all the bubbles come out and top of as you go then when its full and not bubbling in the radiator put the cap and go from there was it the upper or lower hose? and did you put all switches back in the right plug?
Old Apr 3, 2009 | 11:56 PM
i didn't replace the rad hoses. i replace the hose that go from the head (under the vtech solenoid) to a valve that's next to the firewall. it's the one that bends alot not sure if this helps
Old Apr 4, 2009 | 08:25 AM
beutler09's Avatar
double check your fuses mines on all the time but in the winter i just took the fise out cause i didnt need it to run.. you may of blow the fuse
Old Apr 4, 2009 | 08:28 AM
OTiS515's Avatar
id say replace thermostat and refil radiator. mine dosent turn on either, but just figured its staying within a safe temp.
Old Apr 4, 2009 | 09:45 AM
Bartman201's Avatar
fan switch
Old Apr 4, 2009 | 10:07 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
people, we need to simplify even more sometimes.....ck your ground wires and be sure the fan switch plug wires are actually plugged back in.
a buddy had the same issue to find out his fan wires were garbage
Old Apr 4, 2009 | 07:08 PM
i tested it with the plugs and the fan turns on but while idling or driving it doesn't. the car doesn't overheat just that the fan doesn't turn on. forgot to mention i have a fluidyne radiator if it'll have an effect on the fans or not.
Old Apr 4, 2009 | 07:11 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
then it's your switch
Old Apr 4, 2009 | 07:21 PM
where's the switch be located
Old Apr 4, 2009 | 09:35 PM
teknohatchie91's Avatar
just hard wire your fan or fans to a switch in the cabin, thats what i did so i can trun my fans anytime i want or need them to.,
Old Apr 5, 2009 | 06:51 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
no just wire it correctly.
OP, if your car is your "sn" then it's on your thermostat housing, or in it. brown plug
Lred1993civiccx
22
Jun 29, 2019 05:36 PM
dhonda00
Jun 11, 2013 04:14 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
Cuda
Mar 21, 2007 11:25 PM
menappi
Feb 3, 2005 01:23 PM
