HVLP low air gun recommendations?
Hey guys, i'm in the market for a budget low air hvlp/mini/lvlp setup. I'll mostly be doing motorcycle fairings and smaller jobs (don't intend to do cars or bigger jobs). I'll be spraying anything from acrylic enamel to urethane base/top/clear systems (once i experiment and decide which i prefer).
i've got a 25gal 8.3@40 psi compressor, so the higher air consumption guns won't work. I was looking at the asturo mini gun set, though i'm open to other choices.
Also, where's a good e-storefront to order this stuff from? Ordered a 3 gun set from spraygunworld and it's been a month with no product, and marginal customer service, so i'd rather go somewhere else. brick n' mortar places in the LA area work too.
Ideally i'd like to spend less than 200 bucks OTD to get a gun(s), cups, filters, regulators, and the ability to spray base/clear and prime.
Thanks.
Thanks.
i ordered a starter kit from tcpglobal.com it cam with 3 hvlp guns 1 base coat clear coat 1 for primer and a tuchup gun. also cam with gun stand, regulator, small filter, cups basically everything u need to spray except for compressor for 80 bucks.
So have you used these guns yet? How did they spray for you? That kit is in the cfm range of my 30 gallon compressor. I may have to pick this up.
nice, I'm also wondering how the guns spray, looks like a solid starter kit.
i ordered a set too, hopefully it doesn't take too long to get to me, just finished doing my FG repair, filling, etc to a set of fairings.
Those guns will spray ok for the first couple of times then they go downhill really fast.....the best guns you can get are Sata,Iwata, devillbiss...or i have even had really good luck with campbell hausfield and its way cheaper then the above brands
sata, iwata , devillbiss are really good but i was just looking for something cheap i just started in this business.
If you are just getting into the paint business and want to get your name in there,I strongly discourage the use of a cheap gun especially if you are going to paint a whole car or painting any kind of metallic or candy's...you will not like the results and either will your customers..you can get a good sata rp off ebay for around 300-350 and save yourself alot of headaches..trust me i learned the hard way
fake mugen power
Jul 9, 2006 11:14 AM
