car wont start at all, installed new ecu?
Old Apr 3, 2009 | 02:26 PM
Thizzed Out's Avatar
Default car wont start at all, installed new ecu?
Well I ordered a chipped ecu 2weeks ago and installed it today. I tested it out, drove around and my car worked perfect with it. I left it parked for awhile and when I came out to start it, it didn't start at all. I maybe thought my batt. wire was loose so i tightened it down.
The batt. 'the problem (I noticed my stereo, lights etc still work) and the only thing I installed before it fukked up was the chipped ECU. I already tried installing the ECU that it had before but the car still wont start.
The motor doesn't even try to start, I only hear a little click when I turn the key.
What should I do? thanks.
-1995 obd1 gsr
Old Apr 3, 2009 | 02:53 PM
Former User's Avatar
Default Re: car wont start at all, installed new ecu?
The ECU is unlikely to be the problem. Focus on your starter and battery. Try tapping the starter with a rubber mallet. If that doesn't work, test whether the large black wire attached to the starter has battery voltage and then whether the Blk/Wht wire on the solenoid has battery voltage when the clutch is depressed and the key is turned to ON(III).
Old Apr 3, 2009 | 03:01 PM
yeah I was out in the car just now and the wire to the starter came loose. That fixed the problem I just thought maybe it was the ECU because i installed it about 20mins before.
Damn alot of my damn wires have been coming loose lately lol WTF!
thanks again for your help.
Old Apr 3, 2009 | 03:35 PM
SDyang's Avatar
your ground wire n the battery have same problem
97accordidiot
Jul 5, 2014 12:25 PM
CALC!_JUST_du_IT!
Jun 19, 2008 08:31 AM
turboteg90
Nov 28, 2007 02:08 PM
B18C1EKhb
May 2, 2005 03:25 AM
incubus
23
Mar 14, 2004 07:31 AM
