Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
oil burning?
Old Apr 3, 2009 | 10:51 AM
1701j's Avatar
New User
Default oil burning?
Howdy folks, I've got a 2001 civic LX that runs great but needs a qt of oil every 2 weeks. It doesn't smoke at any point of usage and it doesn't leak oil. However I have noticed a build up of oil around the cylinder head. And if I leave the vent open I get the smell of oil burning, or at least cooking from the engine. Could it be that simple as to simply change the head gasket or should I look at replacing the rings. Do O2 sensors have anything to do with increased oil consumption? Thanks for any info.
Joe from Fleetwood, Pa.
Old Apr 3, 2009 | 11:45 AM
DynastyRacer22's Avatar
Default Re: oil burning?
ive had the same problem before it was my headgasket..do you have oil between the block and the head?
Old Apr 3, 2009 | 02:54 PM
1701j's Avatar
New User
Yes, thats exactly where the accumulation is occuring. What are you thinking?
Old Apr 3, 2009 | 04:17 PM
i would check and replace the headgasket and while your at it double check your rings and replace them if needed a qt of oil is alot every 2 weeks i wouldnt wait any longer..how many miles do you have on your car now? mine happened when it was at about 111k oh and replace your timing belt while the head is off unless u have really low milage on it
Old Apr 5, 2009 | 06:32 AM
steve968's Avatar
New User
I would check you cylinder head plug. It is next to the egr solenoid. I would also change the valve cover gasket. Those 2 should solve your problem.
PunchedGuava
28
Sep 8, 2013 11:23 AM
blacktibby07
Feb 13, 2011 09:50 AM
davey5300
Aug 16, 2009 07:29 PM
wm5holla
May 19, 2003 07:30 PM
CivicBoi
May 27, 2002 11:59 AM
