where can i get a harness!!??!?!?!
Old Apr 2, 2009 | 11:48 PM
hondakook's Avatar
Default where can i get a harness!!??!?!?!
heres the dilema i have a b18c-r in my 96 cx the engine harness is from a 99si and i have a p28 chipped ecu with a conversion harness in between. The thing is im not hittin vtec and dont have working a speedometer or tac. My question is which harness would be the best to use if i want to make it obd1 alway through can i use a 96 civic engine harness or do i need to get a type r harness or can i get something close like a gsr? And is this even my problem?
Old Apr 3, 2009 | 02:51 AM
boostin99ek9's Avatar
Default Re: where can i get a harness!!??!?!?!
do you have a OBD1 Distributor on the motor or the stock b-series obd2-b/a? if your running a OBD1 ECU you need the Distributor conversion harness as well... which can be foundhttp://rywire.com/store/obd2-10pin-o...52334d9b9403b0 or http://www.phearable.net/shoppingcar...per-p-102.html orhttp://www.xenocron.com/obd2-10pin-t...a5a52198355a9d just a few of many you could buy from..
Old Apr 3, 2009 | 04:09 PM
94EG8's Avatar
Seagull Management
use a '96 - '98 harness (EX is preferable) and modify it. Using a '99 - '00 harness will leave you with no tach and speedmeter.
Old Apr 5, 2009 | 01:09 AM
hondakook's Avatar
how do i know if i have a obd1 distrubutor im pretty sure i have the stock b series distrubtor that came with the motor. and what and how do i do the modifications on the ex harness
Old Apr 5, 2009 | 06:37 AM
94EG8's Avatar
Seagull Management
If its OBD1 it will have 2 grey plugs, if its OBD2 it will have a single grey plug. You don't need to swap distributors.
If you use a '96 - '98 5 speed EX harness all you have to do is cut and lengthen the wires going to specific sensors, no plugs need to be changed and nothing needs to be added. If you use a CX/DX harness you will need to do some connector swapping. Please see the images below:
JJGL-EF90
Nov 26, 2010 10:30 PM
xdustin513x
Nov 26, 2010 06:22 AM
alexpr
Jun 6, 2010 03:40 AM
oneforce
Apr 24, 2006 10:21 AM
h22blazerz5
Jan 24, 2006 02:18 PM
