M-90 Blower on B18a1 ?
Im currently working on my project car which is a 1988 honda crx si with an obd0 b18a1 swap. Right now the engine is in stock form. Now I seen that the jackson racing supercharger kit for the b-series use's the Eaton m62 supercharger. Well I went to the local junkyard an pulled off an Eaton m90 off of a Grand Prix GTP. Has anyone ever used the m90 on their b-series before? The m62 use's 1liter of air for every revolution an the m90 use's 1.5liters. Is this possible to make it work? I know the car would be alot quicker with the m90 rather than the snail m62.
Lots of info with answers to many of the questions you have now, and others you have probably not thought of yet are right here:
https://honda-tech.com/forums/forced-induction-16/anyone-interested-500-whp-supercharger-kit-1997913/
Alright that answered pretty much everything. So here's what I gathered from that novel thread. 1.Send out crank pulley to be customized to work with my setup
2.Get the tensioner off of a Ford Lighting
3. Use a blow off valve from a talon tsi
4. Ebay FMIC
5. Ebay ic piping with t-bolts
6. Custom supercharger mount bracket
7. Custom supercharger tensioner bracket
8. Send blower out to get the casing done aswell reverse the operation of the blower.
9. Use a 70mm throttle body
10. Larger fuel injectors, walbro 255lph pump, aftermarket fuel pressure reg
11. Hondata s100b
12. 8 rib supercharger belt
13 Dyno tune
Is there anything that Im forgetting?
4. Ebay FMIC
11. Hondata s100b
13 Dyno tune
2.Get the tensioner off of a Ford Lighting $25 junkyard
3. Use a blow off valve from a talon tsi $10 junkyard
4. Ebay FMIC $100
5. Ebay ic piping with t-bolts $100 6. Custom supercharger mount bracket $30
7. Custom supercharger tensioner bracket $30
8. Send blower out to get the casing done aswell reverse the operation of the blower$650
9. Use a 70mm throttle body $280
10. Larger fuel injectors rc 550cc $350, walbro 255lph pump $110, aftermarket fuel pressure reg aem $181
11. Hondata s100b $195
13 Dyno tune $400-500
14 Blower 50-75 bucks at your local junk yard
Its alot cheaper than buying a jrsc kit for a b-series.
4. Ebay FMIC $100
If you guys check out rmcdaniels' thread, he's working with Magnuson on their B-series M90 kit. They're guessing $2500-3k for a comprable kit to the JRSC in terms of parts. The difference is you can use any FMIC, a much better intake manifold, but have to have a more specialized exhaust manifold.
If you want to do it yourself, the problem is your M90 spins the wrong way. You can reverse it, but that requires some specialized machining and pressing/jigs.
blacK_Dc4
Northern California (Sales)
Oct 13, 2010 08:13 PM
