b18a1 swap wont start
i just swapped a 91 b18a1 motor in my 91 civic si and it wont start up. When i try to start it up, i could hear the motor cranking. Would it be soemthin wrong with the fuel, or not enough spark? I really need help and if you can give me suggestions on how to fix the problem that would help alot.
To the OP- when you turn the key to on, listen for the fuel pump to prime, it will be like a humming for 3 seconds, then it will stop. if you hear it, have a friend spray some carb cleaner into the throttle body and if it starts up you arent getting fuel or power to the injectors- causes would be fuel filter, cloged injectors or no power to the injectors-check connections.
to the spark- If you have any spark coming out of the plugs, then its enough to fire the motor. if no power out of the plug wires back track with your test light to find where you loose power.
MassScene
Jan 25, 2007 04:04 PM
