low fuel pressure running lean HELP!
Old Apr 2, 2009 | 07:20 PM
caseyjck20's Avatar
Default low fuel pressure running lean HELP!
so i just put in my gsr swap that i fully rebuilt, its stock except the itr pist and manifold with pr3 head. my problem is my car wasent reving up past like 4k and was not responsive(no chk eng lights on). so i checked my fuel press an it was at 40psi and when regulator hose is kinked it gvets lower. i have a blox fp adjuster and its cranked all the way up?? an still no more than 40 idle and 38psi max at full thottle. shouldnt it RAISE wtf!
i recently checked the fuel line nut to the rail and it had a crush washer smashed in to it blocking the tiny holes. i replaced it and the car now revs up nice like it should but my FUEL PRESSURE is still low i cant get it to go to 47-55 at all. PLUGS are white/light brown!!
stock gsr ecu
single cam vtec injectors
ef hatch obd1 conv
gsr/ b16 head itr pist.
ANYONE with an idea to my prob please comment. thanks alot HT.
Old Apr 2, 2009 | 07:24 PM
Farmer89511's Avatar
Default Re: low fuel pressure running lean HELP!
well i had the some problem the BLOX is junk i used it once and i put the stock one back on...
Old Apr 2, 2009 | 09:31 PM
caseyjck20's Avatar
hmmm it worked on my old car same fuel rail obd0 set up b16 inj. i could adjust it to 60psi or more. and when i give it gas or kink the vacume line on the regulator it would rise 8-10 psi over idle.
Old Apr 2, 2009 | 10:13 PM
caseyjck20's Avatar
does anyone kno if the single cam injectors work on a gsr motor for shur?
Old Apr 3, 2009 | 10:41 PM
caseyjck20's Avatar
bump. installed ls inj. still low pressure and its not rising when throttles applied.
Old Apr 4, 2009 | 04:42 AM
yes single cam injectors will work on a GSR as long as they are same OBD thats all
Old Apr 9, 2009 | 11:34 PM
Targa4Life's Avatar
Are you using the stock flexible fuel line from the filter to the rail? If so, make sure you don't have it on backwards. It has different sized ends on it. the large side should be against the fuel rail. Besides that, let us know if you figured it out.
Psychoteen101
Jul 30, 2009 10:07 PM
caseyjck20
15
Apr 3, 2009 10:49 PM
alpha_1
Nov 22, 2004 06:13 AM
HamiltonRex
Feb 28, 2004 04:55 PM
93preludeh22
Sep 23, 2003 03:38 PM
