ls vtec idle
Old Apr 2, 2009 | 05:06 PM
ninthgatemotorsports's Avatar
New User
Default ls vtec idle
i have a 98 integra ls i just did a b16 head with gsr cams it also is running a 18g turbo with a tial external waste gate now for the problem when u start the car it idles at 3 grand when goes from 1500 to 3 back and forth i cant get it to idle right and sugestions
Old Apr 2, 2009 | 05:40 PM
MumBleZ_94gsR's Avatar
Default Re: ls vtec idle
vacuum problem... most likely in ur throttle body.. i forgot the name but turn the car on and disconnect w.e. tubing u have connected to ur throttle body and listen for a sucking noise and out ur finger where its sucking in the air and if its there u should idle fine with ur finger cover the hole
Old Apr 2, 2009 | 05:55 PM
New User
would running the ls throttle body affect it
Old Apr 2, 2009 | 06:01 PM
im not sure but u should look it up
Old Apr 2, 2009 | 06:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Try the Hybrid forum.
dark_reverie
Aug 15, 2014 12:39 PM
libral00
Jun 16, 2007 04:19 PM
Mr_Moos
Mar 8, 2007 02:25 AM
vtecda
Aug 15, 2005 07:41 AM
sk8phaze
Aug 16, 2002 10:45 AM
