torquing lugnuts-Is a torque wrench accurate?
Old Apr 2, 2009 | 04:50 PM
EG-SIXV-TEC's Avatar
Icon2 torquing lugnuts-Is a torque wrench accurate?
torquing lugnuts-Is a torque wrench accurate with extensions?
Hi im just wondering that if a torque wrench is accurate? i mean that its not really accurate but, i am wondering if you use an extensions will it affact the spec of torque ft lbs that im torquing to?
i am using a regular 1/2" craftsman turn dial ratchet torque wrench and using a 3" extension to a double sided socket 19mm that looks like 1.5" when attatch to , also another 3" Socket for the star key lugnut bolt. Im geusing eight to nine inches?
And i am wondering if when i torque it to my Spec will it be less than dialed foot lbs torque AT?
I heard some people saying that if you add extension you will minus the spec that you calibrated it at?
so maybe about 80 so ft lbs and i torque it my wheels lugnuts i torqued it at will be less than 80ft lbs because of the extension? IS that true?
Old Apr 2, 2009 | 04:57 PM
fireblaze2k1's Avatar
Default Re: torquing lugnuts-Is a torque wrench accurate?
Yeah it's true. Just tighten them down. I tighten mine down as tight as I can, and have never had a problem.
Old Apr 2, 2009 | 04:59 PM
F20B-CX's Avatar
It will be under the spec if you use an extension. Google the actual calculation.
Old Apr 2, 2009 | 05:03 PM
Just out of curiosity, why should you torque the lugs to specs?
batallic's Avatar
yo u double posted
Old Apr 2, 2009 | 05:09 PM
muasboi's Avatar
i have always torqued mine to about 82-83 with extensions, like in your case.
Old Apr 2, 2009 | 05:27 PM
F20B-CX's Avatar
Too loose and they'll wiggle off. Too tight and you'll crack/warp rotors or wheels.
Old Apr 2, 2009 | 05:29 PM
christian7750's Avatar
Who really cares what you torque your freaking lug nuts to? Like it matters. They are suppose to be 80lb
Old Apr 2, 2009 | 05:36 PM
97Ej6mike's Avatar
All honda's with 19mm Lugnuts should be set to 80ft/lbs (all civic, accords, pilot, CRV, insight, s2000, fit). All honda's with 22mm lugs are set to 100ft/lbs (all ridgelines and oddeseys)
Old Apr 2, 2009 | 07:27 PM
batallic's Avatar
Old Apr 2, 2009 | 07:43 PM
Vindicator9000's Avatar
318 Curves, 11 miles
I started doing it when I found out that my car really likes to break wheelstuds for some reason, and they're absolutely terrible to change on the fronts. I also use antiseize on them.
I torque to about 85 with a 4" extension, and haven't broken one since I started doing that.
arren123
Jul 20, 2010 12:51 PM
EG-SIXV-TEC
Honda Civic (2001 - 2005)
Apr 7, 2009 07:32 PM
smxcan
Jan 12, 2009 07:17 PM
