Question on a TPS
Hey guys, how's it going?
Do any of you know reputable sites to buy an aftermarket TPS (throttle positioning sensor) at? I'd rather replace the sensor, than the whole throttle body, seeing how i'm only having problems with the sensor.
The only site i've looked at is OmniPowerUSA.com But i'm not too sure about them. Any ideas?
Oh, your car runs good? Because I've read that if your vehicle throws a TPS CEL, it throws your Vtec into limp mode. Does this happen to you, even after the replaced TPS?
Yeah, that's what I was originally planning. But the only problem is, is that I don't have the tool to remove it. Such as a tool that makes a groove into the bolt so you can remove it with a flat head, for example.
On another note, wouldn't I be able to pull one off an EX and be just fine?
deucedeuceEK
Apr 27, 2007 02:39 PM
homeskillet
20
Jan 10, 2005 02:28 PM
