Suspension
Old Apr 2, 2009 | 01:50 PM
jakem200's Avatar
Default Suspension
Wanting some opinions on some coilover options. I currently drive an 02 EP3 and have been searching around for the best performace per price coilovers. I semi-decided on the Skunk2 Pro S series, since I'll be mainly daily driving the car on the highway. No track racing, no intense turns etc.
I had narrowed it down to the Tein Basics, and the skunk2 proS, and decided on the Skunk2 simply due to cost.
Any other suggestions for nice basic coilovers that's not going to cost an arm and a leg? I found the skunk2's for $850. I have the skunk2 rear camber kit, ingal's front camber adjusting bolts, skunk2 rear tie bar. Car is dropped 3 inches from factory ride height, and I'll probably have it 2.75" down with the adjustables when I finally order them.
Old Apr 2, 2009 | 01:55 PM
nahonda04's Avatar
Surje.motorsports
Default Re: Suspension
i heard of these really cool 2 places you can find out about suspension on this site, one of them is so hard to locate at the top of the page called the FAQ thread, the other is located above that on this page it called the SEARCH button...let me know if you have trouble finding them!
Old Apr 3, 2009 | 06:30 AM
nahonda04's Avatar
Surje.motorsports
Originally Posted by em191
the mans looking for help and your the biggest dick head ever
**** YOU
****in bitch
BTW im 17 years of age
If u use the places i recommended he will get help as this topic comes up like 4-10 times a month. Go fail else where or back to your em1 forum and stay outta here dumbass!!
Old Apr 3, 2009 | 06:48 AM
mustclime's Avatar
**** YOU
****in bitch
I have socks older than you...........
to the op......you stock spring rates are 249lb's progressive rate springs in the ft and 440lb progressive rate springs in the rear.....the junk2 springs are like 672lb strait rate ft and 448lb strait rate rear.....do you see a problem here?
What junk2 people did was look at the corner weights of the ep3 and picked the spring rates to that. The Problem with that is the front suspension has a motion ratio of .98 and the rear has a motion ratio of .588. What this means with out getting into a whole suspension conversation is the spring rates should be higher in the rear than the front.....like honda sold the car from the factory....
Junk2 is just that, junk......You did not state what you planed on using the car for...if its dd, you do not really need coilovers....you also did not list what tires you planed on using, tires help set the spring rates for any suspension....If you are runing all season tires, you have no use for much of in the way of suspension because you stock suspension was tuned for allseason tires....
Old Apr 3, 2009 | 07:00 AM
DaveSi677's Avatar
Sorry but he is right... been covered a million times and you need to learn how to use the FAQs...
You are lucky this guys knows what he is talking about and gave you a very good summary of what you should be looking for when purchasing a suspension for your car!!!
Old Apr 3, 2009 | 08:56 AM
josh's ep3's Avatar
Function > Form
Yeah.. umm what he said lol. BTW from now on mustclime, I'm going to refer to you as "The Suspension Guru" lol.
Old Apr 3, 2009 | 09:55 AM
Aznsensation's Avatar
If you're not even going to be pushing your suspension very hard, why even get coilovers at all? Just get springs. =\
Old Apr 3, 2009 | 11:35 AM
mustclime's Avatar
Old Apr 3, 2009 | 12:12 PM
josh's ep3's Avatar
Function > Form
HAHAHA ^^ Is that a self portrait Mr. Guru?
Old Apr 3, 2009 | 12:34 PM
DaveSi677's Avatar
haha its true Must u know ur stuff... alot more then some of us here when it comes to the handling and suspension!!!
Old Apr 4, 2009 | 05:24 PM
kobeballer96's Avatar
HAHAHA ^ thats one funny dude
kaychi
Suspension & Brakes
May 9, 2008 07:00 PM
VisualAutoMotoring
186
Mar 29, 2007 08:29 PM
SpeedMonkeyRacing
81
Nov 23, 2006 12:39 PM
Kgb
Jul 21, 2005 09:46 AM
