B16 eg wont start!!!!!!!!
Old Apr 2, 2009 | 12:55 PM
'96typeR's Avatar
Post B16 eg wont start!!!!!!!!
wussup! i got an eg with jdm b16. i took out the old wiring harness replace it for new one, the motor turns but doesnt have any spark?? so i put the old harness back on and still the same problem?? i checked make sure everything is plugged in and still nothing.... i appreciate any help! thanks!
Old Apr 2, 2009 | 01:03 PM
Former User's Avatar
Default Re: B16 eg wont start!!!!!!!!
Is the ground wire on the thermostat housing connected?
Do you measure 12V at the distributor coil when the key is turned to ON(II)?
Old Apr 2, 2009 | 01:08 PM
'96typeR's Avatar
yeah the ground is connected, and i havent checked the distributer yet.... ill check that out thanks
Old Apr 2, 2009 | 01:33 PM
JohnnyWash1's Avatar
This seems obvious. Re-check all of your wiring. If it started before you changed harnesses, the answer lies in your wiring.
'96typeR
Mar 21, 2009 02:51 PM
Logan76
Jan 23, 2009 08:14 PM
crxracer2006
Sep 22, 2005 11:46 AM
sk8rmike
Dec 15, 2004 08:16 PM
LSVtecEK1
Apr 25, 2003 09:18 PM
