Lsd Trans
Old Apr 2, 2009 | 12:00 PM
gambit19's Avatar
Default Lsd Trans
I bought a trans yesterday they guy said it has lsd on it how can I tell? I can see a rod threw the diff and still see the other end
Old Apr 2, 2009 | 12:10 PM
quikflip27's Avatar
Default Re: Lsd Trans
If you can see a rod, then it is not LSD equipped. With an LSD equipped trans, you can see straight through the differential, through a hole without any obstruction. With an open differential, you can still see light coming from the other side, but there is a rod crossing through the hole you are looking through. Hope that makes sense.
Old Apr 2, 2009 | 12:12 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
If the tranny has lsd you should be able to see straight through. Sounds like you got jipped.
Old Apr 2, 2009 | 12:14 PM
gambit19's Avatar
Yah it does that fuc* got me. He had also stated that it had carbon sync and a final gear installed any way to tell for that thanks guys.
Old Apr 2, 2009 | 12:18 PM
93egSLEEPER's Avatar
open up the case and take a look. more then likely since there is no lsd like he said there will be no carbon gear.
Old Apr 2, 2009 | 12:19 PM
MonkeyMagic's Avatar
only if you tear it apart.
but based on the lsd alone.. i'd kick some ****in ***
HOODLOVER
51
Apr 8, 2021 04:47 AM
highmilehatch
Jul 18, 2007 06:35 AM
PrecisionH23a
Apr 29, 2006 09:29 AM
Sleeper32
Oct 21, 2003 10:53 AM
NightHawkC5
Feb 27, 2003 10:58 AM
