D15B2 with D16A6 parts.
Old Apr 2, 2009 | 08:16 AM
killercrx91's Avatar
Icon6 D15B2 with D16A6 parts.
I really don't know so that's why i'm ask. Can I take an D16A6 block and tranny and put it on an D15B2? If not does anyone thing the D16A6 tranny can fit the D15B2?
Old Apr 2, 2009 | 09:16 AM
hondaluver12's Avatar
Default Re: D15B2 with D16A6 parts.
The tranny of a d16a6 will bolt up to a d15b2, as long as its a d series it will bolt up. but i dont understand what your trying to ask about the block?
Old Apr 2, 2009 | 10:08 AM
Would the D16A6 Block bolt right up with the D15B2 head?
Old Apr 2, 2009 | 10:09 AM
dr_latino999's Avatar
Yes the castings of the heads are the same.
Old Apr 2, 2009 | 10:25 AM
radex7's Avatar
It is more common, though, to put the A6 head, or at least a cam on B2 block. Apparently after the MPFI swap that is the most common power upgrade.
Old Apr 2, 2009 | 03:05 PM
Yeah I know but it's this I don't what to paly around with the wire harness. So that's why i'm thinking about doing this.
Old Apr 2, 2009 | 07:02 PM
90si-rex's Avatar
The wiring is easy. You basically add a couple of wires and if I remember correctly, extend a couple of others. It should only take you a couple of hours max, and if you get a little stuck, there are plenty of people on here that have done the DPFI to MPFI conversion that can help you out. There are also plenty of good write-ups that detail exactly how to do it. Check out http://www.fourthgenhatch.net/mpfi.html for a good write-up of the process. When I did my swap this helped me more than anything else I found for the wiring.
Dive in headfirst and don't be afraid to ask questions. Good luck!
Old Apr 2, 2009 | 08:43 PM
tkda's Avatar
if you are afraid of the dpfi-mpfi then you can get a si engine harnes and a si under dash harnes and swap everything over. no wire cutting or splicing or any of that.
but let me tell you the wiring for dpfi-mpfi is very easy and much cheaper, but its just not quite as clean.
Old Apr 2, 2009 | 09:46 PM
93formula's Avatar
it can be clean if dont right and with patience....
Old Apr 2, 2009 | 10:30 PM
tkda's Avatar
and wire loom.
Old Apr 2, 2009 | 11:36 PM
DCRB's Avatar
you don't need to keep the b2 head to use dpfi.... you can use an a6 head on dpfi...
Old Apr 2, 2009 | 11:46 PM
DOHCED8's Avatar
dont waste ur time putting an a6 head on a b2. it lowers compression. i have that setup and it blows. multiport is hella easy. add 4 wires swap 2.. it u browse areound u can find the wiring and picture instructions.. all u need is a pm6 ecu, multiport intake mani with rail and injectors, resistor box, alot of wire, a very small precision flat-head screw driver to de-pin plugs, and solder. after ur done.... its worth it
Old Apr 2, 2009 | 11:48 PM
DOHCED8's Avatar
oh and a a6 dizzy
Old Apr 3, 2009 | 04:26 AM
Hey thanks. I'm goin to look around on that page. But if I do the DPFI to MPFI conversion i'm putting the Si engine this because it has the HP I what and I can do more things to it... Because I know with the B16A1 Vtec I would this kill myself =P.
Old Apr 3, 2009 | 04:33 AM
Furyof4's Avatar
FALSE. They are the same casting as said before. Same chamber cc's.
OrangeBoost
May 4, 2006 02:49 PM
headhunter
Feb 22, 2005 02:26 PM
GSRCRXsi
12
Dec 2, 2004 07:30 PM
CivicSiRracer69
Jun 26, 2004 01:22 PM
gulf imports
Jul 19, 2003 01:13 AM
