Read Disk Question (Stolen Delsol)
Old Apr 2, 2009 | 06:42 AM
MrMug3n's Avatar
Default Read Disk Question (Stolen Delsol)
my 93 Delsol Si was stolen and i am struggling to rebuild it. The thieves took everything including the driverside rear disk brakes...
My question to H.T. is will integra rear disk brakes work on my delsol? is so do i haft to replace everything including the passenger side?
Old Apr 2, 2009 | 06:45 AM
MonkeyMagic's Avatar
Default Re: Read Disk Question (Stolen Delsol)
i believe the teg **** is identical
Old Apr 2, 2009 | 07:59 AM
MrMug3n's Avatar
the arms, calipers, rotors, ext.?
Old Apr 2, 2009 | 09:33 AM
EL Vap133's Avatar
They took the complete rear disk brakes? If so, the Integra (90-01) rear disk brakes are a direct bolt on.
Old Apr 2, 2009 | 09:45 AM
Carcrazy1
Guest
Posts: n/a
It will fit but a lot of adjustment and synchronisation will be required
Old Apr 2, 2009 | 09:47 AM
SoCal EJ1's Avatar
uh... how? it's a matter of installing the new trailing arm/rotors/pads/etc, adjusting parking cables, and getting an alignment. what synchronization are you talking about?
Old Apr 2, 2009 | 09:51 AM
EL Vap133's Avatar
What is this you speak of? It is a direct bolt on, the Del Sol and the Teg trailing arms are virtually identical.
Old Apr 2, 2009 | 09:54 AM
Since 1983's Avatar
if your going to put the teg ones on it is recommended that you buy the fronts as well, along with a new brake booster and proportioning valve.
Old Apr 2, 2009 | 11:49 AM
MrMug3n's Avatar
direct bolt on, meaning i do not have to replace the passenger side if i use integra parts for the drivers side?
Old Apr 2, 2009 | 05:33 PM
Since 1983's Avatar
The integra brakes are larger, so if you have sol brakes on one side and teg brakes on the other it will work im sure but it wouldn't work correctly.
Old Apr 2, 2009 | 06:18 PM
MrMug3n's Avatar
thanks looks like im replacing both sides...
Old Apr 2, 2009 | 07:46 PM
thumper64's Avatar
The 90-93 Integra arms are different from the 94-01 in that at least the trailing arm bushings are different. Look up the part numbers. And the rotors are too.
Jim Dan
Honda Civic (2001 - 2005)
Apr 17, 2013 12:42 PM
Gas Man
Jan 3, 2011 12:08 AM
lhd dc2
Mar 18, 2009 08:13 PM
integra*RS*
May 20, 2002 10:03 PM
