EG Cluster Chipped Ecu Tps/Map Sensors 550cc Injectors
Old Apr 1, 2009 | 10:32 PM
JDM-JAMES's Avatar
Default EG Cluster Chipped Ecu Tps/Map Sensors 550cc Injectors
here is what i have
1 chipped p06 ecus vtec converted 5speed includes re burnable sst 27sf512 chips i can load any map onto it for any D,B,F,H, Series motors ls vtec b20vtec turbo or all motor maps i can set rev limit vtec engagement disable knock or o2 sensors add 2 step and shift lights hit me up with what you need im asking 110 firm for the ecu
I also have a virgin gsr p72 ecu also 5 speed got it in a trade works great no cel's asking 150
D16y7 Throttle body no map sensor everything else is their 10 bucks
Bunch of sensors and injectors
FIC (Fuel Injector Clinic) 550cc Injectors Retail is 289 asking 175
includes injector seals i had laying around.
2 HONDA OEM TPS Sensors Working 10 each
4 map sensor 10 each
Oem Honda o2 sensor working 25
Eg 92-95 cluster plug and play if your car doesn't have a tach asking 80
you can call or text 619-813-5149 im in the San Diego 92116 area near
mission valley
Thanks James
Old Apr 1, 2009 | 11:36 PM
c4agmaddness's Avatar
Default Re: EG Cluster Chipped Ecu Tps/Map Sensors 550cc Injectors
pmed
Old Apr 2, 2009 | 02:05 PM
JDM-JAMES's Avatar
bumpp
Old Apr 2, 2009 | 11:00 PM
JDM-JAMES's Avatar
bump
Old Apr 3, 2009 | 02:40 AM
Thizzed Out's Avatar
bump...If only u had this up last week.
Old Apr 3, 2009 | 02:54 AM
EcHoB18C1's Avatar
bump
Old Apr 3, 2009 | 01:03 PM
JDM-JAMES's Avatar
thanks
Old Apr 4, 2009 | 09:47 PM
siblue_gzer's Avatar
got pics of the injectors? and is it saturated?
Old Apr 5, 2009 | 12:52 AM
DailyDrivenDB8's Avatar
pm'd
Old Apr 6, 2009 | 12:03 AM
JDM-JAMES's Avatar
and the injectors are
Peak and Hold/ Low Impedance
Old Apr 6, 2009 | 11:55 AM
JDM-JAMES's Avatar
bump
Old Apr 7, 2009 | 10:56 PM
JDM-JAMES's Avatar
bump
Old Apr 7, 2009 | 11:03 PM
Black-Ty [EG6]'s Avatar
bump pm'd
JDM-JAMES
Mar 20, 2009 07:52 AM
Carbcivic
11
Oct 11, 2007 05:45 PM
bigwill_2004
17
Jun 20, 2006 08:43 PM
