car help for a noob with a del sol
Old Apr 1, 2009 | 09:57 PM
604sol's Avatar
Icon6 car help for a noob with a del sol
hey there so the last couple of days i noticed my 93 stock del sol around 225000km not really driven hard sol do this weird thing. Whenever im in idle and just waiting for the light to turn green and the engine is already warm, my revs suddenly drop to 0 and then jump back up. my normal rev is about 900 800 but then it drops to 0 then flickers. does anyone know whats going on?. i can feel the engine dieing on me then starts back up. but when im driving it feels okay.=( help as well does this happen to you guys? first time hearing it?
Old Apr 1, 2009 | 10:02 PM
93egSLEEPER's Avatar
Default Re: car help for a noob with a del sol
are you throwing a CEL?
Old Apr 1, 2009 | 10:21 PM
604sol's Avatar
mmm no the engine light doesn't come on.
Old Apr 1, 2009 | 10:29 PM
sounds like it could be a TPS (throttle position sensor) or IAVC sensor going bad. have you adjusted anything on the throttle body at all?
Old Apr 1, 2009 | 10:32 PM
604sol's Avatar
mm nope havent really tampered with stuff. but ya i think it may be a sensor as well.. even though i dont know much about this stuff.. thanks. ill try to bring it into my uncles shop see what he thinks. mm if the engine light doesnt turn on the cost of fixing it wont be too bad? lol
Old Apr 1, 2009 | 10:41 PM
its hard to say cost. if it just a sensor it should be a fairly cheap and easy deal. i would check all your sensor connections as well and make sure they are all snug.
Old Apr 2, 2009 | 12:12 AM
aasarsak's Avatar
x2 for the TPS get it checked
Old Apr 2, 2009 | 03:27 AM
MWLW20's Avatar
IACV - Roaming/Surging idle when the engine is cold
FITV - Roaming/Surging idle when the engine is warm
Air in coolant system as well? Check out this thread https://honda-tech.com/forums/showth...highlight=fitv
Clean out your IACV and tighten up your FITV....hope that helps
Old Apr 2, 2009 | 03:52 AM
BDeckerB16A's Avatar
Originally Posted by 93egsleeper
sounds like it could be a tps (throttle position sensor) or iavc sensor going bad. Have you adjusted anything on the throttle body at all?
+1
Old Apr 2, 2009 | 06:32 AM
bmxmacdaddy's Avatar
ignition switch or fried ecu(doubtful). If i remember correctly, if its the ignition switch you wont throw a cel.
Old Apr 2, 2009 | 06:34 AM
If the IACV Idle Air Control Valve, your idle wont go to 0, it will surge some where between 800 to 1800 over and over.
Old Apr 2, 2009 | 06:44 AM
vadimkag's Avatar
I had same problem with IACV, had to change it.
Old Apr 2, 2009 | 06:57 AM
thumper64's Avatar
All the sensors are pretty straight forward to change out, and the junkyard shouldn't charge you much, or maybe my local yard just likes me.
Old Apr 2, 2009 | 02:20 PM
604sol's Avatar
hmm well it does it when the engine is warm. but especially does it when it rains?...vancouver....**** weather=(
kirkfreeman
11
Apr 4, 2015 09:31 AM
zc92hatch
13
Apr 22, 2011 03:27 PM
beaver619
21
May 18, 2008 10:10 PM
sick93sol
Jun 13, 2007 06:38 PM
