View Poll Results: Which intake for my B16A?
Stock box and tube. Sounds boring, cool air.
15
27.78%
Short ram. Sounds amazing, more power, heat soak?
26
48.15%
Other. Tell me what you're thinking.
13
24.07%
Voters: 54. You may not vote on this poll
B16A Intake Poll
The stock one is too quiet, but it does a better job of keeping the air cool, yet it's more restrictive. VTEC could sound a lot cooler too. Better filtering?
The short ram sounds intoxicating in VTEC, makes more power, but supposedly it's more prone to heat soak. My butt dyno tells me it's faster.
I don't have money to spend on a Comptech intake either, because that's the best of both worlds.
By the way I have both the stock intake and a short ram and am not going to purchase anything else.
Test Test Test on a dyno every motor is different just have to test a few diffrent setups to see what works the best for your own personal setup
Use the stock intake box but remove the resonator in the fender and add a K&N filter. That's basically what the Comptech box is. The main restriction on your stock box is the stock filter.
Also, using the stock box you won't need to worry about heat soak or cops ticketing you for an illegal intake.
Any short ram intake with any filter would be good enough for your b16a. Ebay or not, just anything thats 64-66mm tubing with any filter to attach, like the good old K&N filter.
Well, I tried all of the above. I currently am running a generic short ram, it's a 3" diameter and the length is exactly the same as the stock intake, but it's so loud! It's only really loud when I hit VTEC, but man, seriously, it's loud. My butt dyno can't tell much of a difference since the rest of my engine is stock right now. I sold my Mugen 4-1 and RS*R Exmag, but I have a 2.5" setup coming sometime.
x2 I have it, very pricey setup but well worth it. Short ram that gets cold air it really is the best of both worlds you wont ever hydrolock which is usually the worry with CAI. Feeling the heat in the engine bay I woul not puta short ram on my car. I replaced my comptech foam filter with a K&N cone. The CT foam filter was just gone it was falling apart and I got a K&N which is my prefered brand for filters for the same price and I know it wont fall apart and crumble after so many miles. IMO you cant really tell much difference in intake setups
) but the 6" K&N filter on it looks redonculous.
