ECU code #15
Old Apr 1, 2009 | 08:08 PM
JLefevers's Avatar
Default ECU code #15
91 hatch W/ OBD0 LS swap. All stock
ok I am getting a visable spark from the dizzy, but cranks "sometimes" and sputters at 3000 rpms. Then sometimes it wont crank at all.
Code #15 Ignition output signal
The dizzy looks to have been exposed to H2O, all internals are covered in rust. I have replaced with a known working OBD0 ignition coil and still the same results. Should I just break down and pick up a new dizzy for this car.
Old Apr 1, 2009 | 09:35 PM
csingham's Avatar
crazy mad murdock
Default Re: ECU code #15
got a friend with a spare or your old D16 distributor?
Old Apr 2, 2009 | 06:31 PM
JLefevers's Avatar
the dseries will not bolt up and I used the coil out of the dseries one and still no crankie.
Old Apr 2, 2009 | 09:52 PM
1904wrencher's Avatar
Did you try the ignition harness. If you have power and the radio works. Then it could be the ignition harness.
Old Apr 3, 2009 | 06:01 AM
jlicrx's Avatar
code 15 is not the coil - it is the igniter
Old Apr 3, 2009 | 07:47 PM
JLefevers's Avatar
cool thanks for the info
90crvtec
Aug 19, 2005 07:19 PM
EGJDM
Feb 5, 2005 12:27 PM
shorty91
Jun 27, 2003 07:55 PM
CRexDX
Apr 10, 2002 06:37 AM
