engine mounts Q for ek
i was wondering if eg b series mounts would fit in to a ek cause i might do a b18b1 swap in to a ek bust not too sure if the stock mounts would fit in..let me know
the rear stock mount you can use, you need a rear t bracket from a integra,99-00 si, you need the b series bracket that bolts to the block between the timing belt, but im not sure about thr trans mount or the engine mount timing belt side
99-00 SI Drivers side upper mount (some people say you need the bracket that bolts to the block and the bar that connects from that to the mount as well, I didn't)
99-00 SI/94-01 Integra rear T bracket.
99-00 SI/94-01 Integra tranmission upper mount bracket, lower front transmission mount
The A/C bracket can be any B series bracket.. if you want to retain a/c (if equipped) use a p30 or the crv bracket.
You can't use the Integra rear T bracket, its considerably longer than the '99 - '00 Si version
again the integra T bracket doesn't work
Integra upper mount doesn't work here either, use the upper transmission bracket from any 5 speed '96 - '00 civic
thanks for all the inf..o i forgot to ask how bouts the stock 92-95 harness would that plug right ups to the ek harness cause its wats on the motor right now...
nope...you will need a EK harness because its 1 piece ...the eg/dc is 2 piece...use the stock one on your car now....since its a LS motor you wont have to worry about vtec...just extend wires...and depending if the motor is obd1 or obd2...you might need to swap out the distributor plugs and injector plugs...but read up on the engine swap guide stickies....i did my swap years ago...so forgot a few details...
mnskateboarder
Apr 12, 2008 11:34 PM
blackeg
May 2, 2005 07:50 AM
deviant1
Mar 21, 2003 11:03 PM
