Oil spraying out head!!!
Old Apr 1, 2009 | 05:41 PM
christian7750's Avatar
Default Oil spraying out head!!!
Did LS/VTEC swap, what head gasket is suppose to be used?
Old Apr 1, 2009 | 05:47 PM
sde780's Avatar
Default Re: Oil spraying out head!!!
Google says LS headgasket
Old Apr 1, 2009 | 06:13 PM
Ya Digg's Avatar
Taken from the Reliable LS/VTEC thread
Originally Posted by bambam
Make sure you have already installed the oil galley plug into the head and that it sits flush, this is imperative to redirect the oil flow via the external oil lines to activate vtec. Alot of people complain about oil leaks with lsvtec setups. You ask them if they installed this plug and they ask you "what is that"?.....
Old Apr 1, 2009 | 06:28 PM
We used the LS head gasket and the hole is plugged
Old Apr 1, 2009 | 06:29 PM
Ya Digg's Avatar
where exactly is it coming from?
Old Apr 1, 2009 | 06:30 PM
Right above the oil filter
Old Apr 1, 2009 | 06:42 PM
Ya Digg's Avatar
Did you torque all the head studs correctly/ use new ones?
Old Apr 1, 2009 | 06:43 PM
geebs's Avatar
What dowel pins did you use?
Old Apr 1, 2009 | 06:47 PM
ARP head studs. Torqued to spec.
Old Apr 1, 2009 | 06:48 PM
Ya Digg's Avatar
x2
Old Apr 1, 2009 | 06:50 PM
LS dowel pins
Old Apr 1, 2009 | 06:53 PM
geebs's Avatar
Did the pins fit in the head fine? I didn't think they used the same sized dowel pins.. Or did you get the holes opened?
Old Apr 1, 2009 | 06:54 PM
I guess they fit ok, didnt do anything to the head
Old Apr 1, 2009 | 06:57 PM
geebs's Avatar
They share the same part number..
It's coming from above the oil filter? you're 100% sure?
Old Apr 1, 2009 | 06:59 PM
100% sure its above the oil filter. The head was already on a LS block, we bought it from the guy and slapped it on our block. So the head already worked on a LS block.
Old Apr 1, 2009 | 08:07 PM
SOHCNightmare's Avatar
In for answer.
Old Apr 1, 2009 | 10:25 PM
I guess the mechanic when he sprayed copper crap on the head gasket sprayed the thing that says up so it was on upside down. Gotta buy a new one a put it on, pretty sure that was why it was leaking. I'll post again when new gasket is one and let everyone know if that fixed it.
Old Apr 2, 2009 | 12:33 AM
aasarsak's Avatar
yeah, while you're at it, why don't you take that head over to a machine shop to make sure it isn't warped. Might as well get it hot tanked and pressure checked while your at it. and check the block deck for squareness. prefereably at a machine shop if you can.
Old Apr 2, 2009 | 01:53 AM
TheRappist's Avatar
Yea, might as well get the crank polished too. Then send the block out and have it sleeved and bored over. Then some 14.5:1 pistons and Pauter rods, and call it a day.
Old Apr 2, 2009 | 01:57 AM
aasarsak's Avatar
Originally Posted by therappist
yea, might as well get the crank polished too. Then send the block out and have it sleeved and bored over. Then some 14.5:1 pistons and pauter rods, and call it a day.
wtf? Lol
Old Apr 2, 2009 | 05:50 AM
sde780's Avatar
wtf? Lol
e-sarcasm at its finest
Old Apr 2, 2009 | 06:39 AM
bmxmacdaddy's Avatar
yeah, get theat head plained, its cheap and smart...and adds .0000001 psi compression
Old Apr 2, 2009 | 02:49 PM
It has already been re-surfaced, crank has been polished, block has been hot tanked, and it is square.
Old Apr 2, 2009 | 02:57 PM
aasarsak's Avatar
good. looking forward to your results.
Old Apr 3, 2009 | 04:00 AM
OK, after replacing the head gasket and making sure it was right side up we turned the car over and what do ya know, oil spraying again. BUT, my friend swore it was from the head, yet we saw it coming from the intake manifold with closer inspection. SO, we took off the intake manifold and low and behold there is a hole in the middle of the head that was pumping out oil the whole time. There should be an allen bolt that goes in that hole that was definitely not in it. So we have to get that bolt, slap her on and she should be good to go.
