Crank Pulley lines for TDC
My manual tells me that to set the engine to TDC, the crank pulley on my 95 GSR is suppose to have a white line that i would need to line it up with the plastic cover.
Now i believe the problem is that the white line on my crank pulley wore out. After examining the crank pulley, i found 3 groves or etches pretty close to each other on the crank pully and another etches about an inch away from from those 3.
Which one was suppose to be the white line that line up to the plastic peice for TDC?
Anyone knows?
Anyone knows?
As I remember, TDC is the last notch. It's not the three but the one an inch away. You can also check the cam gears to see if they line up at TDC.
Anyone knows?
Anyone knows?
RTW DC2R
May 23, 2005 10:33 AM
ej1 pilot
10
Jan 7, 2005 07:50 PM
216.226.142.95:27016
Jul 2, 2003 07:52 AM
TurboBumblBee
May 24, 2003 10:19 AM
