anyone ever heard of a witness mark
after my t belt install on my jdm d15b i put the cam gear at tdc then i was looking for the mark on the crank pully and all that was there was a little W engraved...my friend said it stand for witness mark which is what you line it up to....anyone heard this? i just dont want my motor to blow up soon as i get it started...TIA
Re: anyone ever heard of a witness mark (Art In Motion)
On mine there was a pointer on the crankshaft, and then a mark on the oil pump to line it up to. Never heard of a witness mark.
no marks on your crank pulley? at all nothing, not even notches
If not time to get a new pulley because I have no idea how you are going to time your car.
there should be 3 marks real close to each other looking something like this( ||| ), and then one single one by itself which is what you line up with the pointer on your plastic cover. this isnt on your crank pulley???
Re: anyone ever heard of a witness mark (lohatch)
yeah im pretty sure its not all i see is a W...is it on the top of the crank pully or the flat surface thats parallel to the motor?
their is a white mark on the pulley, and there is an etch in the shaft itself if you take the pulley off. Either will work.
Re: anyone ever heard of a witness mark (92Lx)
ill try to get my friend to snap it with his digicam but ill probly be starting it today...crossing my fingers
here just do this, put a screw driver or something really really long into a #1 spark plug hole and rotate it by hand do not crank it. And look for a place where the screw driver or whatever you put in there sticks up the most. That's your TDC.
RTW DC2R
05-23-2005 10:33 AM
Nextelbuddy
03-29-2004 11:43 AM
TurboBumblBee
05-24-2003 10:19 AM
