S2p2 vs s2p1
No...Pro2s or Pro3s won't put down any more power than Pro1s. There's no reason Skunk2 makes 3 different cams with different specifications...it's all just a marketing ploy!
Thats exactly what I thought. People say they make more power with the pro 1's. THanks for the input.
I haven't measured them, but I'm sure Don or Tom could give you that information.
https://honda-tech.com/forums/showth...highlight=pro1
Originally Posted by Tbone
and 1 more thing, the pro-2 primarys are smaller then the pro-1 primarys so that throws your whole stage 2 is bigger then 1 and 3 is bigger then 2...
^ haha, was wondering about that for a while myself too, and then finally found it:
https://honda-tech.com/misc.php?do=showsmilies
Also, in your profile, if you change the default quick reply formatting to advanced it will give you a drop down menu of the smillies.
Are you talking about the primaries? I don't know who to believe because I'm sure both Tom and Don have measured pretty much all the cams on the market.
In the thread I linked the Skunk2 sales exec argued against Tom, but in the end he conceded (after checking with his technical staff) that the regular Stage3 cams have smaller primaries than the Stage2's. Perhaps they did the same thing with the Pro cams.
I was under the possibly mis-informed impression, the P1 has the same primaries as the P2. Although there was an initial batch of P1's (that Blox copied) Skunk revised to help the cams idle. And the P1 has more lift where the P2 has more duration.
