What end links to use w/ Function7 LCA's
Old Apr 1, 2009 | 11:25 AM
BoS_DC2's Avatar
Default What end links to use w/ Function7 LCA's
Hey there fellow Honda-Techers......
A buddy of mine is running Function 7 LCA's with CTR Sway bar setup on his EM1. He's wondering what endlinks will work with this setup.
Thanks guys!
Old Apr 1, 2009 | 12:29 PM
Meoshe's Avatar
Default Re: What end links to use w/ Function7 LCA's
His stock ones should work, if not get heim joint styled ones
Old Apr 2, 2009 | 09:54 PM
BoS_DC2's Avatar
The stock ones don't work, the F7 LCA's are too beefy..
Old Dec 17, 2009 | 05:48 AM
Sypherg's Avatar
New User
You are correct.
I too run a CTR Sway + ASR + F7 LCA combo. However OEM EK9 endlinks cannot be used as bolt is not right size.
I had to use F7 spherical endlinks however i now find it too noisy for daily (as expected). Can you suggest which endlinks do fit F7 LCA + EK9 Sway on EK besides F7?
Only 2 other company that come to mind are: Hardrace and Blox
Anyone tried if those endlinks fit this setup?
Apologies for bumping an old thread. I will put an intro soon as i am a noob here.
Thanks in advance.
Old Dec 17, 2009 | 09:39 AM
Finnish_Racer's Avatar
well to bring this to life again, i am looking into Blox....i'm just wondering if they're a reputable company cause i've heard some things about Skunk 2.....so just wanting to make sure.
Old Dec 17, 2009 | 11:01 AM
mrnicolas's Avatar
here is what a blox endlink looks like after 3 months on my friends car. He does not drive hard at all and this happened.
he was using an itr 22mm rear sway, asr brace, skunk2 lcas on his 98 hatch
Old Dec 17, 2009 | 12:56 PM
theres your first problem
maybe you just got a bad link ?
Old Dec 17, 2009 | 05:12 PM
Sypherg's Avatar
New User
So what else people tried besides BLOX? Anyone using Hardrace (non spherical)? more suited for daily.
Old Dec 17, 2009 | 05:24 PM
blox makes a non spherical for oem sway bars.
Old Dec 17, 2009 | 05:25 PM
i called passwordjdm.com and talked to em for a bit.
Blox makes fantastic products apparently and the broken endlink may have just been a fluke.
Old Dec 17, 2009 | 05:41 PM
Sypherg's Avatar
New User
Hi Finnish Racer,
Do you have a link or model number for the Blox endlink product you are using with your Function7 LCA? I am interested to see this as OEM replacement (rather then noisy spherical)
Thanks
Old Dec 17, 2009 | 07:45 PM
i'm not going to be using an F7, i'll be using a Megan Racing lca.
http://www.redlinemotive.com/store/b...-end-links.asp
all of this is theoretical until i get the proper finances.
Old Dec 17, 2009 | 08:23 PM
Sypherg's Avatar
New User
Sounds promising best of luck.
Old Dec 17, 2009 | 08:24 PM
Sypherg's Avatar
New User
I will have to stick with F7 endlinks until i find a suitable substitute that performs like OEM (not noisy)
Old Dec 18, 2009 | 06:59 PM
that works. anything for the man who needs it!
Old Apr 14, 2011 | 06:11 AM
305civictyperaw's Avatar
Sorry for bumping an old thread but i have the same question & setup as OP.
what endlinks would u guys recommend for my setup? ill be purchasing a 22MM ITR Sway Bar
thanks in advance, here's a pic:
Old Apr 14, 2011 | 10:09 AM
i can pick up some BLOX endlinks for $40 locally.
what do u guys think? will they work ok?
Old Apr 14, 2011 | 12:00 PM
98civdx's Avatar
Master Detailer
The question has already answerd!
I have the blox endlinks, they are crap and bearly lasted a year. I will be replacing with function7.
I have them on my front 26mm, and 13mm rear sway bar.
Old Apr 14, 2011 | 12:12 PM
ok thanks bro just re-confirming...
Old Apr 14, 2011 | 02:34 PM
redline303's Avatar
im running an asr 24mm sway bar with the asr endlinks and i love the links idk if they will fit the function 7's but idk why they wouldnt lets hope they do cuz i plan on pickin some 7's up soon
Old Apr 15, 2011 | 04:24 AM
ok cool. please let us know if they work with F7's lol thanks
Old Apr 15, 2011 | 05:26 AM
K20egcw's Avatar
I read on here that people were having the same probably with F7 end links as they do with BLOX. They are made by the same people, just packaged differently. I went with the BLOX after hearing that.
Old Apr 15, 2011 | 07:49 AM
Red_Army's Avatar
so you bought blox?...some people.
Old Apr 15, 2011 | 10:54 AM
K20egcw's Avatar
Yup, I did. Why would I pay $70 for the same blox end link repackaged and sold from F7 when I could buy the exact same thing for cheaper?
Old Apr 15, 2011 | 11:25 AM
98civdx's Avatar
Master Detailer
I am having a pretty hard time understanding this. What are you trying to say? Blox is better?
Blox endlinks suck
You didn't pay less for the same exact thing. You paid less, for a lower quality peice, that isn't going to last nearly as long. Yes, these endlinks will never last a really long time, but there are people who have years on the F7 endlinks. Where mine didn't make it a year.
The quality difference should be cristal clear, howver some i guess will just stick to buying low quality parts. My blox endlinks cost $36, F7 $49, spend the extra couple bucks and get the better part!
