intake arm, air breather/coolant line question..
Old Apr 1, 2009 | 08:56 AM
Petah's Avatar
Default intake arm, air breather/coolant line question..
Theere is a metal bracket hose that connects the breather hose located on the intake arm and valve cover, what is the purpose of this? On this same bracket, there is also a connection that connects a coolant line between the throttle body and head. Does anyone know why this coolant line is connected the way it is? It looks like most people just removed this bracket and coolant line via a soft rubber hose.
Thanks.
Old Apr 1, 2009 | 09:23 AM
Dave-ROR's Avatar
Default Re: intake arm, air breather/coolant line question..
You can bypass that coolant line, but there's no great reason to depending on your goals. That setup was designed the way it is for ease of packaging and routing. It's not ideal. Most aftermarket intakes substitute that setup for 2 rubber hoses.
Old Apr 1, 2009 | 12:02 PM
get RIGHT's Avatar
It just vents crankcase vapors and/or any excessive oils.
Old Apr 1, 2009 | 05:35 PM
98itRspec's Avatar
I see a cool air intake. It's got a NOS fogger system and a T4 turbo, Dominic. I see an AIC controller. It has direct port nitrous injection. Yeah. And a stand-alone fuel management system. Not a bad way to spend $10,000.
I kid.
Old Apr 1, 2009 | 05:50 PM
Petah's Avatar
I kid.
LOL, someone is a F&F fan?!
Old Apr 2, 2009 | 10:52 AM
jawtee22's Avatar
Ready for tomorow.
Old Apr 2, 2009 | 11:05 AM
THE LORD OF CHAOS's Avatar
most people bypass it and just run a hose for the coolant and a hose for the vacuum connection from the vc.
personally i rerouted the coolant line, and i plugged the nipple of the my aem short ram with a vacuum cap and i just have a breather filter on the vc.
96DelSol
Jan 4, 2012 06:48 AM
TooManyTickets
Jun 24, 2007 03:17 PM
Evolution-93-Ex
13
Mar 7, 2006 01:04 PM
Krayzielix
Jun 17, 2004 03:42 AM
Audipwr1
Jul 8, 2003 11:02 AM
