fuel pump is not turning on....help!!!!!!!
Old Apr 1, 2009 | 08:43 AM
on-site ej1's Avatar
Icon3 fuel pump is not turning on....help!!!!!!!
i reasently did a wire tuck on my gsr and now that all is done i cant get the motor to start!!!! i dont hear the fuel pump come on and ive checked the under the hood fuse box, the connections to the fuel pump, under the steering wheel main fuse relay and its all good.. but then i moved on to the ecu, i seen that on one of the plugs on of the wires was burnt up and was disconnected then i tried to connect it back together using another wire........ and still dont hear it... can it be that my ecu got burned up or what the hell is wrong with it.. HELP ME OUT!!! PLEAZE!!!
Old Apr 1, 2009 | 09:43 AM
HONDRETTI's Avatar
Default Re: fuel pump is not turning on....help!!!!!!!
which wire was burnt up? have you tried pulling any codes?
i would,
a) check for codes
b) try a different main relay
c) try a different ecu
Old Apr 1, 2009 | 10:06 AM
it was some yellow wire that comes out the gray plug.. and when i get home ima try a different ecu... thanks for the help!
Old Apr 1, 2009 | 10:20 AM
ozzyman's Avatar
I think you got some of your wires mixed up. Look at a wiring schematic for the fuel pump and make sure the wires running from the pump are going into the correct pin on the connector for ecu.
Old Apr 3, 2009 | 09:30 AM
EG6KILIN's Avatar
man i got the same problem!!!!!
96coupecivic
Jan 23, 2012 09:00 PM
RICE POLICE SIP
Apr 21, 2010 03:26 PM
1988EfKing
Aug 31, 2009 06:32 AM
tegdude227
Jan 31, 2009 03:59 PM
n8barton
Dec 2, 2004 02:38 PM
