Suspension bumpstop question
Old Apr 1, 2009 | 12:07 AM
FRKWOO's Avatar
Default Suspension bumpstop question
i recently changed up my suspension set up to tokico blues with ground controls and i heard that you didnt need the bumpstops anymore with the ground controls and if u do leave them on they make terrible squeeking noises?
Old Apr 1, 2009 | 11:53 PM
FRKWOO's Avatar
Default Re: Suspension bumpstop question
anyone??
Old Apr 2, 2009 | 04:01 AM
BDeckerB16A's Avatar
I dont know much about this setup but I have never heard of removing the bump stop completely. I would say cut the bump stop in half if anything. They are there for a reason.
Old Apr 2, 2009 | 05:05 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Yes, you still want your bumpstops or it could damage something when you bottom it out. Generally on a lowered car though, OEM bumpstops are too long, and you'll be hitting them constantly, causing a rough ride.
At least on my koni reds, the directions say to trim 35mm from the bottom, which is almost halfway. I think that's a good place to start.
Old Apr 2, 2009 | 05:21 AM
infinitypro12's Avatar
Nice! It is good to see more people doing this. I did mine last summer and I did cut to the instructions specifications from Ground Control. And the person above ^ is correct if you bottom out with no bumpstop your going to be replacing your strut/shock again. I don't notice any squeeking but even if that was the case I would rather deal with that rather than buying a new shock/strut, lubrication also helps.
Old Apr 2, 2009 | 09:48 AM
FRKWOO's Avatar
anyone know if i need to change the dust boot or not if i drop it lower would the dust boot be long and get smushed?
Old Apr 2, 2009 | 12:13 PM
you can cut the dust boot if you need to, but I just left mine the same length and it was fine.
Old Apr 2, 2009 | 12:21 PM
NMBB6's Avatar
I did the same thing for mine, you want to keep it so dust and other debris don't get onto your shocks.
frankietyper
Suspension & Brakes
Nov 10, 2014 12:04 PM
napalm588
Mar 30, 2008 03:20 PM
siqueen23
Mar 24, 2008 09:09 PM
reeder321
Oct 13, 2005 12:28 PM
rjr162
Jul 25, 2003 06:45 AM
