why does my car smoke
Old Mar 31, 2009 | 02:35 PM
EEWagonBol's Avatar
Default why does my car smoke
was asking i have a 90 wagovan awd with a stock d16 in it just headers and intake when i drive my car starts to smoke white around 3grand but the head gasket is new and i gave it an oil change not to long ago dont know whats up wit my car somebody help
Old Mar 31, 2009 | 05:05 PM
QuickStyle's Avatar
Default Re: why does my car smoke
white smoke = coolant in the combustion chamber. if its got a new head gasket, it might have a warped head, did you check it for straightness when you had it off? improperly torqued head bolts? get a coolant system pressure tester and see where its leaking at.
Old Mar 31, 2009 | 05:18 PM
EEWagonBol's Avatar
my cuz did it he told me that it might be the valve stem seals but i dont know maybe another motor
Old Mar 31, 2009 | 05:22 PM
QuickStyle's Avatar
valve stem seals would cause blue smoke.
white smoke = coolant in combustion chamber
blue smoke = oil in combustion chamber
black smoke = too much fuel in combustion chamber
Old Mar 31, 2009 | 06:07 PM
EEWagonBol's Avatar
thanx a lot i gonna check it out 2marrow i was driving my car not to long ago and it was not smoking like that i had wanna my bols follow me wit his car and he said that it looks like blue smoke when i pull off and it goes away when i rev up but after like four and a half grand its starts to smoke agian i dont know what it might be u think if i change the head would it stop smoking cause i was gonna get a vtec head from 94 ex coupe and say f u c k it
Old Mar 31, 2009 | 07:37 PM
dephtone's Avatar
Before you just drop cash on a z6 head you better make sure that your block isn't warped. throwing a new head on the car if it's coolant isnt going to solve your problem. Is the smell sweet or does it smell.....well....like burnt oil? Changing the head would not necessarily make the smoking go away. If it happens to be bad valve stem seals in the head, and if the z6 head is used there is always a chance those seals may be bad as well.
Does the car hesitate at all? Have you pulled the spark plug to see if possibly you are getting oil down in the spark plug tubes? My HF did this and I found my spark plug tube seals were shot and needed replaced.
Old Mar 31, 2009 | 07:43 PM
EEWagonBol's Avatar
i am gonna check it out 2 marrow if anything i would come back and post whats the problem thanx
Pelayo94
Apr 12, 2014 07:01 PM
tollickj
Nov 15, 2011 07:19 AM
cars101
20
May 6, 2007 02:38 PM
tbuck23
Apr 26, 2007 05:10 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
